Compile needs a rebuild to load TTGO LoRa32Esp
steinerrw
Postby steinerrw » Wed Dec 27, 2023 1:29 pm
I'm running sketches on a TTGO LoRa32 Esp board...
I have all libraries and boards defined and it works with a catch.
The first compile is OK. Compile again and I get this
Arduino: 1.8.19 (Linux), Board: "TTGO LoRa32-OLED, TTGO LoRa32 V2, 80MHz, 921600, None, Enabled"
WARNING: Category '' in library ESP Insights is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library ESP RainMaker is not valid. Setting to 'Uncategorized'
WARNING: Category '' in library WiFiProv is not valid. Setting to 'Uncategorized'
panic: runtime error: index out of range [8] with length 8
goroutine 1 [running]:
arduino.cc/builder.(*includeCache).Next(...)
	arduino.cc/builder/container_find_includes.go:209
arduino.cc/builder.findIncludesUntilDone(0x4000100400, 0x400028e4b0, {{0x1452e0, 0x40008b13b0}, {0x400010c10d, 0x7}})
	arduino.cc/builder/container_find_includes.go:321 +0xdec
arduino.cc/builder.(*ContainerFindIncludes).Run(0x4000130180?, 0x4000100400)
	arduino.cc/builder/container_find_includes.go:149 +0x974
arduino.cc/builder.runCommands(0x400008fb78?, {0x40003c7c48?, 0x22, 0x22db8?}, 0x0?)
	arduino.cc/builder/builder.go:191 +0xd4
arduino.cc/builder.(*Builder).Run(0x7fec93f237?, 0x19?)
	arduino.cc/builder/builder.go:124 +0x748
arduino.cc/builder.RunBuilder(...)
	arduino.cc/builder/builder.go:222
main.main()
	arduino.cc/arduino-builder/main.go:338 +0xa58
arduino-builder returned 2
Error compiling for board TTGO LoRa32-OLED.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Now if I change on of the build options ie. core debug, erase flash, upload speed and compile again it work/uploads...
Can you fix or have a solution.
lbernstone
Re: Compile needs a rebuild to load TTGO LoRa32Esp
Postby lbernstone » Wed Dec 27, 2023 7:09 pm
Remove and re-install the esp32 board from board manager.
steinerrw
Postby steinerrw » Fri Jan 12, 2024 10:50 pm
Thanks for the reply but I forgot to mention that I had done that and it did not fix issues.
lbernstone
Postby lbernstone » Sat Jan 13, 2024 5:58 pm
Try reinstalling Arduino IDE, or roll back to 1.8.16 (or roll forward to 2.x). This is pretty certainly an error in the IDE with how they are caching the build files.
Users browsing this forum: Amazon [Bot], meta-externalagent and 2 guests
