To Isolate the issue, I've created a fresh project in platformio with the following platformio.ini content:
Code: platformio.ini Select all
[env:seeed_xiao_esp32c3]
platform = espressif32
board = seeed_xiao_esp32c3
framework = espidf
monitor_filters =
send_on_enter
esp32_exception_decoder
build_type = debug
build_flags =
-std=gnu++20
-g
-Og
build_unflags =
-std=gnu++11Code: main.cpp Select all
#include "freertos/task.h"
unsigned int cause_stack_overflow(unsigned int current_depth = 0) {
printf("Stack depth: %u\n", current_depth);
if (current_depth < 0x1 << 31) {
cause_stack_overflow(current_depth + 1);
return current_depth;
extern "C" void app_main() {
printf("Output Start\n");
vTaskDelay(pdMS_TO_TICKS(5000));
printf("Output %u\n", cause_stack_overflow());
printf("Output End\n");
}- Ensuring that my PlatformIO version is up-to-date (6.1.11, which is the latest as of now)
- Ensuring that the ESP-IDF version is up-to-date (5.1.2 which is the latest stable release of the espidf right now)
- Ensuring that the build_type in platformio is set to "debug"
- Ensuring that esp32_exception_decoder is set in monitor_filters
- Adding the -g and -Og build flags to ensure that the compiler left in debugging symbols
- Running a clean build and upload after reinstalling all relevant packages
- Searching for documentation that might be helpful such as the platformio official documentation which contains very little information.
- Searching for ESP documentation, which seems to only cover use with the Arduino IDE (I am not using arduino libraries, and am only using the espidf).
Code: Untitled.txt Select all
Stack memory:
3fc8d040: 0x3fc8d044 0xffffffff 0x3c021660 0x403892c0 0x3fc8b2ac 0x3c021660 0x3fc8b290 0x3c021102
3fc8d060: 0x3fc8b2bc 0x3fc8d074 0x3fc8b2c0 0x3c021134 0x3fc8aed4 0x32373233 0x00000000 0x65737361
3fc8d080: 0x66207472 0x656c6961 0x70203a64 0x6f4e7672 0x79666974 0x75657551 0x74655365 0x746e6f43
3fc8d0a0: 0x656e6961 0x44492072 0x6f635c46 0x6e6f706d 0x73746e65 0x6572665c 0x6f747265 0x72465c73
3fc8d0c0: 0x54526565 0x4b2d534f 0x656e7265 0x75715c6c 0x2e657565 0x32333a63 0x28203237 0x75517870
3fc8d0e0: 0x53657565 0x6f437465 0x6961746e 0x2d72656e 0x4d78753e 0x61737365 0x57736567 0x69746961
3fc8d100: 0x3c20676e 0x51787020 0x65756575 0x43746553 0x61746e6f 0x72656e69 0x78753e2d 0x676e654c
3fc8d120: 0x00296874 0x6564206b 0x00000010 0x42003b64 0x00000011 0x00000011 0x00000011 0x4038126a
3fc8d140: 0x00000011 0x00000000 0x00000000 0x42000000 0x00000004 0x3fc8d2e0 0x3c020130 0x00000000
3fc8d160: 0x00000000 0x00000000 0x3fc8fda4 0x40383ac8 0x00000011 0x00000000 0x3fc8d070 0x3fc8d070
3fc8d180: 0x00000000 0x00000000 0x3fc8d070 0x40383f80 0x00000011 0x3fc8f48c 0x3fc8cedc 0x00000000
3fc8d1a0: 0x00000011 0x3fc8f48c 0x3fc8cedc 0x3fc8d070 0x00000001 0x3fc8f48c 0x3fc8cedc 0x00000000
3fc8d1c0: 0x00000000 0x3fc8f430 0x3fc8d070 0x40384130 0x00000000 0x00000004 0x3fc8d21c 0x403811c0
3fc8d1e0: 0x00000000 0x00000004 0x3fc8d22c 0x00000001 0x00000000 0x3c02012f 0x00000001 0x4038126a
3fc8d200: 0x00000003 0x3fc8cedc 0x3c020130 0x4038139a 0x00000000 0x3c02012f 0x3fc8d2e0 0x3fc8d070
3fc8d220: 0x00000000 0x3c02012f 0x00000001 0x4200d480 0x00000000 0x3c02012f 0x00000001 0x3fc8f48c
3fc8d240: 0x3c02012f 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000011 0x00000001
3fc8d260: 0x00000003 0x00000000 0x00000000 0x3c0284d0 0x00000000 0x00000000 0x00000000 0x00000000
3fc8d280: 0x3c027a74 0x00000000 0x3c0278f8 0x00000000 0x3c027a74 0x00000000 0x3c0278f8 0x00000000
3fc8d2a0: 0x3c027a74 0x00000000 0x3c0278f8 0x3fc8d678 0x3c027a74 0x00000000 0x3c0278f8 0x00000001
3fc8d2c0: 0x00000000 0x00000000 0x3c0278f8 0x00000001 0x00000000 0x00000000 0x3c0278f8 0x00000001
3fc8d2e0: 0x3fc8d2ec 0x00000000 0x00000000 0x3c02012f 0x00000001 0x3fc8d38d 0x00000003 0x3c02012f
3fc8d300: 0x00000001 0x3fc8d39d 0x00000003 0x3c02012f 0x00000001 0x3fc8d3ad 0x00000003 0x3c02012f
3fc8d320: 0x00000001 0x3fc8d3bd 0x00000003 0x3c02012f 0x00000001 0x3fc8d3cd 0x00000003 0x3c02012f
3fc8d340: 0x00000001 0x3fc8d3dd 0x00000003 0x3c02012f 0x00000001 0x3fc8d3ed 0x00000003 0x3c02012f
3fc8d360: 0x00000001 0x3fc8d3fd 0x00000003 0x3c02012f 0x00000001 0x3fc8d40d 0x00000003 0x3c02012f
3fc8d380: 0x00000001 0x3fc8d41d 0x00000003 0x3636342f 0xffffffff 0x3fc8d42d 0x00000003 0x3536342f
3fc8d3a0: 0xffffffff 0x3fc8d43d 0x00000003 0x3436342f 0xffffffff 0x3fc8d44d 0x00000003 0x3336342f
3fc8d3c0: 0xffffffff 0x3fc8d45d 0x00000003 0x3236342f 0xffffffff 0x3fc8d46d 0x00000003 0x3136342f
3fc8d3e0: 0xffffffff 0x3fc8d47d 0x00000003 0x3036342f 0xffffffff 0x3fc8d48d 0x00000003 0x3935342f
3fc8d400: 0xffffffff 0x3fc8d49d 0x00000003 0x3835342f 0x000001d2 0x3fc8d4ad 0x00000003 0x3735342f
3fc8d420: 0x000001d1 0x3fc8d4bd 0x00000003 0x3635342f 0x000001d0 0x3fc8d4cd 0x00000003 0x3535342f
