Logging stops working after i2c_new_master_bus()
Posted: Tue Jan 02, 2024 4:09 pm
I am using an ESP32-C3-DevLit-M1 and try to speak to a sensor via I2C. In order to do that I create a new I2C master bus using
imported from i2c_master.h. When I call this function the log stops working. There is one last truncated entry and nothing else is printed anymore. The program seem to work properly since it shows the correct behaviour. Nevertheless nothing is printed in the logs after that call. What am I doing wrong?
Log output:
Code which call the I2C-function:
i2c_master_init():
esp_err_t i2c_new_master_bus(const i2c_master_bus_config_t *bus_config, i2c_master_bus_handle_t *ret_bus_handle);Log output:
I (414) main_task: Started on CPU0
I (424) main_task: Calling app_main()
I (424) [BATHROOM_SENSOR]: Starting bath room app...
I (424) gpio: GPIO[5]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (434) gpio: GPIO[5]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (444) gpio: GPIO[2]| InputEn: 0| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:0
I (454) gpio: GPIO[2]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
I (464) [App]: Setting up the app...
I (464) [App]: └── Initializing I2C master bus...
I (474) gpio: GPIO[20]| InputEn: 1| OutputEn: 1| OpenDrain: 1| Pullup: 0| Pulldo
void App::setup() {
ESP_LOGI(TAG, "Setting up the app...");
esp_err_t status = ESP_OK;
status = i2c_master_init();
if (status != ESP_OK) {
ESP_LOGE(TAG, "└── Failed to initialize I2C master bus. Reason: %s", esp_err_to_name(status));
esp_deep_sleep_start();
ESP_LOGI(TAG, "└── Initialized I2C master bus. Status: %d", status); // <- This is not printed anymore.
// more code omitted
esp_err_t App::i2c_master_init() {
ESP_LOGI(TAG, "└── Initializing I2C master bus...");
i2c_master_bus_config_t config = {
.i2c_port = -1, // auto select
.sda_io_num = I2C_GPIO_SDA,
.scl_io_num = I2C_GPIO_SCL,
.clk_source = I2C_CLK_SRC_DEFAULT,
.glitch_ignore_cnt = 7, // recommended
.intr_priority = 0, // auto select
.flags = {
.enable_internal_pullup = 0,
return i2c_new_master_bus(&config, &_i2c_bus_handle);
