Github actions & IDF Component Manager
kaspernyhus
Postby kaspernyhus » Sat Jan 06, 2024 10:05 pm
I'm trying to use the espressif github actions `espressif/esp-idf-ci-action@v1` to build a project in my CI pipeline that uses the IDF Component Manager to fetch a component from a private github repo.
I made a test project with this manifest file:
idf_component.yml
## IDF Component Manager Manifest File
dependencies:
  espressif/button: "^2.5.0"
  ## Required IDF version
  idf:
    version: ">=4.1.0"
  # For components in git repository:
  esp_arithmetic:
    path: "./component_add"
    version: "*"
    git: "git@github.com:kaspernyhus/multi_component_test.git"
because this repo is private github actions cannot fetch this code.
The authenticity of host 'github.com' can't be established.
ECDSA key fingerprint is
How can I give the IDF Component Manager running on github access to this private git repo?
Thanks!
kaspernyhus
Re: Github actions & IDF Component Manager
Postby kaspernyhus » Mon Jan 08, 2024 11:07 pm
I have tried including ssh-agent in the workflow and passing ssh keys from repo secrets, and setting known_hosts in different ways but I still get the error:
The authenticity of host 'github.com (140.82.112.3)' can't be established.
ECDSA key fingerprint is SHA256:p2QAMXNIC1TJYWeIOttrVc98/R1BUFWu3/LiyKgUfQM.
the only solution I can think of right now is to check 'managed_components' and 'dependencies.lock' into git and make sure that the versions match so the workflow wont have to update the dependencies.
That doesn't seem to be the most elegant solution though...
kaspernyhus
Postby kaspernyhus » Wed Jan 10, 2024 12:23 pm
and I suspect that it will only work with esp-idf v.5 and above.
Tried building in CI with managed_components folder and dependencies.lock checked in with esp-idf v4.4.4 and it doesn't work. Even though the manifest files haven't changed it seems the build system tries to connect to the private repo.
With esp-idf v5.1.1 it works...
kaspernyhus
Postby kaspernyhus » Wed Jan 10, 2024 2:29 pm
might have found the solution in the docs:
https://docs.espressif.com/projects/idf ... n-manifest
but I struggle with getting the component manager to read the environment variable set in github actions because these might not get passed into the docker image running the build
kaspernyhus
Postby kaspernyhus » Wed Jan 10, 2024 4:29 pm
Here is a modified workflow that allows for passing an access token
https://github.com/kaspernyhus/esp-idf-ci-action
.github/workflows
run-name: "${{ github.actor }}: building esp-idf application"
on: [pull_request, push]
jobs:
  build:
    runs-on: ubuntu-latest
    steps:
    - name: Checkout repo
      uses: actions/checkout@v2
    - name: Build with ESP-IDF
      uses: kaspernyhus/esp-idf-ci-action@v1
      with:
        access_token: ${{ secrets.ACCESS_TOKEN }}
        esp_idf_version: v4.4.4
        target: esp32s3
idf_component.yml
dependencies:
  idf:
    version: ">=4.1.0"
  esp_arithmetic:
    version: "*"
    git: https://$ACCESS_TOKEN@github.com/kaspernyhus/multi_component_test.git
Users browsing this forum: Baidu [Spider], Bing [Bot], PetalBot and 1 guest
