Multiple Devices on SPI Bus
rith87
Postby rith87 » Wed Jan 17, 2024 11:58 pm
Hello folks,
I have a DM9051 and a CC1201 running on the same SPI Bus. Both of them use polling transactions (spi_device_polling_transmit()) and work fine together most of the time. However, occasionally, I'll get a few errors like:
E (54778) spi_master: spi_device_acquire_bus(977): Cannot acquire bus when a polling transaction is in progress.
E (54788) spi_master: spi_device_polling_start(1043): Cannot send polling transaction while the previous polling transaction is not terminated.
What is the best practices approach when working with multiple devices on the same SPI bus? Suppose the following scenario:
  • Task 1 calls spi_device_acquire_bus()
  • Task 1 calls spi_device_polling_transmit() and sets the polling flag to true
  • Task 2 calls spi_device_acquire_bus()
At this point, I would have expected Task 2 to wait until Task 1 has called spi_device_release_bus() but looking at the code, it seems like it fails instead?
SPI_CHECK(!spi_bus_device_is_polling(device), "Cannot acquire bus when a polling transaction is in progress.", ESP_ERR_INVALID_STATE );
So, does this mean that the best practice here is to do some error checking and retrying when calling spi_device_acquire_bus()?
joseMiguel
Re: Multiple Devices on SPI Bus
Postby joseMiguel » Thu Jan 18, 2024 7:36 am
Sorry, if it is a silly question
I suppose that you have two CS (Chip Select "CS" or not Chip Select "nCS")
One for each external circuit?
Regards
José Michel
José Michel
rith87
Postby rith87 » Thu Jan 18, 2024 5:08 pm
Yup, the CC1201 and DM9051 share the same SPI bus but they have their own individual CS line.
kammutierspule
Postby kammutierspule » Wed Jan 15, 2025 7:55 am
Same question:
esp_err_t SPI_MASTER_ISR_ATTR spi_device_acquire_bus(spi_device_t *device, TickType_t wait)
SPI_CHECK(!spi_bus_device_is_polling(device), "Cannot acquire bus when a polling transaction is in progress.", ESP_ERR_INVALID_STATE);
esp_err_t ret = spi_bus_lock_acquire_start(device->dev_lock, wait);
So what is the purpose of the spi_bus_lock_acquire_start when it is not possible to acquire if is polling?
It means we need to mutex protect the device externally?
Users browsing this forum: Baidu [Spider], Google [Bot] and 7 guests
