ERROR_INVALID_PYTHON installing VSCode plug-in
felixkasza
Postby felixkasza » Sat Jan 20, 2024 7:45 am
Downloading C:\Users\fk\.espressif\dist\idf-git-2.39.2-win64.zip...
idf-git-2.39.2-win64.zip has (28527) KB
idf-git-2.39.2-win64.zip progress: 0.06% (16.00 / 28526.53) KB
[… progress messages elided …]
idf-git-2.39.2-win64.zip progress: 100.00% (28526.53 / 28526.53) KB
Installing C:\Users\fk\.espressif\tools\idf-git\2.39.2 ...
Extracted C:\Users\fk\.espressif\tools\idf-git\2.39.2 ...
idf-python-3.11.2-embed-win64.zip has (13776) KB
idf-python-3.11.2-embed-win64.zip progress: 0.12% (16.00 / 13775.83) KB
idf-python-3.11.2-embed-win64.zip progress: 100.00% (13775.83 / 13775.83) KB
Extracted C:\Users\fk\.espressif\tools\idf-python\3.11.2 ...
Looking in links: c:\temp\tmpyrdhkj2h
Processing c:\temp\tmpyrdhkj2h\setuptools-65.5.0-py3-none-any.whl
Processing c:\temp\tmpyrdhkj2h\pip-22.3.1-py3-none-any.whl
Installing collected packages: setuptools, pip
  WARNING: The scripts pip3.11.exe and pip3.exe are installed in 'C:\Users\fk\.espressif\tools\idf-python\3.11.2\Scripts' which is not on PATH.
  Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
Successfully installed pip-22.3.1 setuptools-65.5.0
C:\Users\fk\.espressif\tools\idf-python\3.11.2\python.exe is not valid. (ERROR_INVALID_PYTHON)
This happens when I install ESP-IDF 5.1.2 of 5.0.5 (no other versions tried) and the VSCode ESP-IDF plug-in under Windows 11 on a VM that was reset to the initial state after every attempt. Oh, and the download server (Github or Espressif) makes no difference as far as I can tell; I tried both.
Attempt #1. ESP-IDF into c:\esp, tools into c:\esp-idf into c:\esp\tools; plugin installed with "advanced" and these paths. ERROR_INVALID_PYTHON.
Attempt #2. ESP-IDF into its default paths, plugin installed as above. ERROR_INVALID_PYTHON.
#3. No pre-installed ESP_IDF, plug-in install does all the work ("advanced" with downloading)
I tried half a dozen additional combinations, but they all lead to:
The path to python.exe varies according to what I am trying, but it is always correct: There really is a python.exe there, and it is the only one in the system.
Dear Espressif folks, under which condition(s) is the ERROR_INVALID_PYTHON raised? Knowing this might give me a hint on fixingthe problem. Thanks!
Cheers,
Felix.
jerive
Re: ERROR_INVALID_PYTHON installing VSCode plug-in
Postby jerive » Sat Jan 20, 2024 6:18 pm
Hi Felix, I had the same issue, and this link helped me solve it: viewtopic.php?t=23976
Deleting idf-git and idf-python folders in C:\Espressif\tools and trying the installation again worked for me.
felixkasza
Postby felixkasza » Sun Jan 21, 2024 2:46 am
Thank you! I am much obliged!
Cheers,
Felix.
Users browsing this forum: ChatGPT-User, Google [Bot], PetalBot, Qwantbot, Semrush [Bot] and 4 guests
