I am looking if this is possible and if there is an example code around?
1) The Ethernet (W5500) connects to a device and provides DHCP (DHCP server running on Ethernet port).
2) Data received from Ethernet is processed.
3) Data is then sent out through the WIFI STA (DHCP is from AP).
Device <--> Ethernet <--- ESP32 ---> WIFI STA <---> AP
Where Ethernet - ESP32 - WIFI STA is on one PCB board (ESP32-Ethernet-Kit).
ESP32 Ethernet with WIFI STA
Re: ESP32 Ethernet with WIFI STA
Check examples at https://github.com/espressif/esp-idf/tr ... es/network if any suits your needs.
Did you manage to get anything working?
I am trying to do a similar project. I found some "eth2wlan" which sort of does the job, but it seems to loose 93% of the data, so I am really struggling!
Users browsing this forum: Amazon [Bot], Qwantbot and 2 guests
