Where's the rest of the internal memory?
vonnieda
Postby vonnieda » Fri Dec 01, 2017 8:05 pm
I started to run into some memory issues in my project this morning, so I am spending some time debugging memory. I noticed there seems to be less internal memory than the datasheet indicates and am wondering how to access it.
I'm using a WROVER32KIT v3 and if I build the following tiny app, it reports "227560" on startup.
#include "sdkconfig.h"
#include "esp_system.h"
#include "esp_log.h"
#define TAG "TEST"
void app_main()
	ESP_LOGI(TAG, "%d", esp_get_free_heap_size());
The datasheet says that the ESP32 has "520 kB (8 kB RTC FAST Memory included) of on-chip SRAM for data and instructions." So where is the other 290k hiding, and is there a way to use it?
FWIW: I'm aware of the SPI RAM, and am using it in my project. This came about because I ran out of internal RAM specifically when allocating FreeRTOS task stacks.
Thanks in advance for any light you can shine!
Thanks,
Jason
WiFive
Re: Where's the rest of the internal memory?
Postby WiFive » Sat Dec 02, 2017 5:48 am
heap_caps_get_free_size(MALLOC_CAP_8BIT)
heap_caps_get_free_size(MALLOC_CAP_32BIT)
First will show DRAM, second will show DRAM+IRAM
vonnieda
Postby vonnieda » Sat Dec 02, 2017 5:13 pm
Thank you for the response WiFive, but I'm still not seeing the full amount. Here's the new test program and output:
#include "esp_heap_caps.h"
#define TAG "TEST"
void app_main()
    ESP_LOGI(TAG, "MALLOC_CAP_8BIT %d", heap_caps_get_free_size(MALLOC_CAP_8BIT));
    ESP_LOGI(TAG, "MALLOC_CAP_32BIT %d", heap_caps_get_free_size(MALLOC_CAP_32BIT));
I (256) TEST: MALLOC_CAP_8BIT 299304
I (256) TEST: MALLOC_CAP_32BIT 395940
So it seems like there is at least another 124k missing?
igrr
Postby igrr » Sun Dec 03, 2017 3:19 am
There is also statically allocated memory (both IRAM and DRAM), you can see the amount by running "make size". Plus a 64kB region of IRAM used for CPU caches.
vonnieda
Postby vonnieda » Tue Dec 05, 2017 4:23 am
Thank you ESP_igrr, I think that clears it up for me. If I add up all those numbers I get close enough to 520k.
Thanks,
Jason
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 0 guests
