SPI does not work
Posted: Sat Jan 27, 2024 3:01 pm
I have got XIAO ESP32S3 and ESP32-WROOM32 units. I have got exactly the same problem on both. SPI works on Arduino but it does not on ESP-IDF. I use ESP-IDF 5.1.2.
I setup SPI by using code below. Later I send 4 bytes
I receive wrong data, always the same bytes no matter what 4 bytes are sent. Screenshot from logic analyzer:
When I use Arduino
Everything is correct. I can write and read data without problems. Screenshot from logic analyzer below. Everything is fine.
When I start program on Arduino later on ESP-IDF you can clearly see differences on logic analyzer
Hardware connection is fine because it works on Arduino. It is something wrong with configuration on ESP-IDF (I have spent lots of time trying different configurations). It is something incorrect with PINS or MOSI or CLOCK or ... . Behavior is the same on XIAO ESP32s3 and ESP32 units ( I reconfigure pins of course ). Tried VSPI and HSPI.
Did someone have similar issue?
Code: Untitled.cpp Select all
//On XIAO I tried
//gpio_iomux_in(GPIO_NUM_9, SPI3_D_IN_IDX);
//gpio_iomux_out(GPIO_NUM_8, SPI3_Q_OUT_IDX, false);
//gpio_iomux_in(GPIO_NUM_7, SPI3_CLK_IN_IDX);
//gpio_iomux_in(GPIO_NUM_1, SPI3_CS0_IN_IDX);
// and this
//gpio_iomux_out(GPIO_NUM_9, SPI3_D_OUT_IDX, false);
//gpio_iomux_in(GPIO_NUM_8, SPI3_Q_IN_IDX);
//gpio_iomux_out(GPIO_NUM_7, SPI3_CLK_OUT_IDX, false);
//gpio_iomux_out(GPIO_NUM_1, SPI3_CS0_IN_IDX,false);
spi_bus_config_t Config;
Config.mosi_io_num = GPIO_NUM_23;//GPIO_NUM_9;//GPIO_NUM_13;//
Config.miso_io_num = GPIO_NUM_19;//GPIO_NUM_8;//GPIO_NUM_12;//
Config.sclk_io_num = GPIO_NUM_18;//GPIO_NUM_7;//GPIO_NUM_14;//;
//Config.mosi_io_num = GPIO_NUM_9;
//Config.miso_io_num = GPIO_NUM_8;
//Config.sclk_io_num = GPIO_NUM_7;
Config.max_transfer_sz = 0;
Config.quadwp_io_num = -1; // -1 not used
Config.quadhd_io_num = -1; // -1 not used
Config.intr_flags = 0;
Config.data0_io_num = -1;
Config.data1_io_num = -1;
Config.data2_io_num = -1;
Config.data3_io_num = -1;
Config.data4_io_num = -1;
Config.data5_io_num = -1;
Config.data6_io_num = -1;
Config.data7_io_num = -1;
//Tried with SPICOMMON_BUSFLAG_NATIVE_PINS, SPICOMMON_BUSFLAG_NATIVE_PINS, SPICOMMON_BUSFLAG_GPIO_PINS
Config.flags = SPICOMMON_BUSFLAG_MASTER;// | SPICOMMON_BUSFLAG_NATIVE_PINS;// | SPICOMMON_BUSFLAG_MISO | SPICOMMON_BUSFLAG_MOSI;
Config.isr_cpu_id = INTR_CPU_ID_0;
if(ESP_OK == spi_bus_initialize(SPI3_HOST, &Config, SPI_DMA_CH_AUTO))//SPI_DMA_DISABLED);//SPI_DMA_CH_AUTO);
printf("-----OK-----");
//spicommon_bus_initialize_io
spi_device_interface_config_t ConfigInterface;
ConfigInterface.command_bits = 0;
ConfigInterface.address_bits = 0;
ConfigInterface.dummy_bits = 0;
ConfigInterface.mode = 0;
ConfigInterface.duty_cycle_pos = 128; // default 128 = 50%/50% duty
ConfigInterface.cs_ena_pretrans = 0; // 0 not used
ConfigInterface.cs_ena_posttrans = 0; // 0 not used
ConfigInterface.clock_speed_hz = 500000;
ConfigInterface.clock_source = SPI_CLK_SRC_APB; //SPI_CLK_SRC_DEFAULT
ConfigInterface.spics_io_num = GPIO_NUM_5;
ConfigInterface.flags = 0;//SPI_DEVICE_HALFDUPLEX | SPI_DEVICE_NO_DUMMY; //| SPI_DEVICE_HALFDUPLEX;
ConfigInterface.queue_size = 1;
ConfigInterface.pre_cb = NULL;
ConfigInterface.post_cb = NULL;
ConfigInterface.input_delay_ns = 0;
if(ESP_OK == spi_bus_add_device(SPI3_HOST, &ConfigInterface, &SPIHandle))
}I receive wrong data, always the same bytes no matter what 4 bytes are sent. Screenshot from logic analyzer:
When I use Arduino
#include <Arduino.h>
#include <SPI.h>
#define VSPI_MISO 19
#define VSPI_MOSI 23
#define VSPI_SCLK 18
#define VSPI_SS 5
SPIClass * vspi = NULL;
void setup()
printf("Start");
pinMode(VSPI_SS, OUTPUT);
vspi = new SPIClass(2);
vspi->begin(VSPI_SCLK, VSPI_MISO, VSPI_MOSI, VSPI_SS); //SCLK, MISO, MOSI, SS
void loop()
//uint16_t addressToRead = 0x0740;
uint16_t addressToRead = 0x08E7;
vspi->beginTransaction(SPISettings(500000, MSBFIRST, SPI_MODE0));
delay(10);
digitalWrite(VSPI_SS, 0);
vspi->transfer(0x0D);
vspi->transfer16(addressToRead);
vspi->transfer(0x38);
digitalWrite(VSPI_SS, 1);
vspi->endTransaction();
delay(2000);
delay(10);
vspi->transfer(0x1D);
vspi->transfer(0x00);
uint8_t regValue = vspi->transfer(0x00);
printf("Reg %u", regValue);
delay(2000);
printf("Stop\n");
}Everything is correct. I can write and read data without problems. Screenshot from logic analyzer below. Everything is fine.
