Creating a mesh network without a router connected
Carboxyl
Postby Carboxyl » Mon Jan 29, 2024 6:18 am
Hey!
I'm new to IDF and am transitioning over from the Arduino IDE. This is my first larger project here.
I'm trying to create a routerless mesh network where every sensor on the network will dump all messages published on the network to serial, where a python program will pick them up and parse them. Right now, I'm getting a few problems with this snipping in just initializing the mesh configuration.
void initialize_mesh_network(){
    // Initialize ESP-IDF components
    Serial.println("Event loop started");
    // Wi-Fi configuration
    wifi_init_config_t wifi_cfg = WIFI_INIT_CONFIG_DEFAULT();
    ESP_ERROR_CHECK(esp_wifi_init(&wifi_cfg));
    ESP_ERROR_CHECK(esp_wifi_set_storage(WIFI_STORAGE_RAM));
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA));
    ESP_ERROR_CHECK(esp_wifi_start());
    Serial.println("WiFi initialized");
    // Mesh network configuration
    mesh_cfg_t mesh_cfg = MESH_INIT_CONFIG_DEFAULT();
    mesh_cfg.channel = 1;
    memcpy((uint8_t *)&mesh_cfg.mesh_id, "BungleNet", strlen("BungleNet"));
    mesh_cfg.mesh_ap.max_connection = 8;  // Example max connections
    memcpy((uint8_t *)&mesh_cfg.mesh_ap.password, "bungus", strlen("bungus"));
    // // Explicitly indicate no router connection for a routerless setup
    // mesh_cfg.router.ssid_len = 0;
    // memset(mesh_cfg.router.ssid, 0, sizeof(mesh_cfg.router.ssid));
    // memset(mesh_cfg.router.bssid, 0, sizeof(mesh_cfg.router.bssid));
    ESP_ERROR_CHECK(esp_mesh_init());
    ESP_ERROR_CHECK(esp_mesh_set_config(&mesh_cfg));
    Serial.println("Mesh network configured");
    ESP_ERROR_CHECK(esp_mesh_set_max_layer(25));
    ESP_ERROR_CHECK(esp_mesh_start());
from this, I get problems actually initializing the network, or if I swap the lines
I then get that the router configuration was not set correctly. Should I be using esp_mesh_set_self_organized? I was looking at this post
https://esp32.com/viewtopic.php?t=15022
And not getting very far. I'd genuinely appreciate a lecture or two on how this is done :)
Thanks!
rsimpsonbusa
Re: Creating a mesh network without a router connected
Postby rsimpsonbusa » Mon Jan 29, 2024 6:45 pm
I presume you do not want or have a WiFi available but still need a mesh. I had a similar requirement, for example if you are going to use LORA instead of WiFi, or just collect data an store it. Anyways, what I ended up doing is using another ESP32 in STA mode so that it will provide the REQUIRED WiFi access for the Mesh. You can not have a Mesh without WiFi, its been extensively documented.
Use this ESP32 “wifi” node to be your logger, network access for LORA or whatever. They are cheap and in the future, if you finally get access to “real” wifi just connect to this network. It would be a good idea to name the ESP32 STA ssid to something that in the future will be a real SSDI WiFi.
A point to consider is that with the virtual WiFi you cannot have access to MQTT, HTTP etc, just internal messages.
Hope it helps.
tanmanh0707
Postby tanmanh0707 » Sun Aug 03, 2025 12:03 pm
Hi, did you resolve this issue? Is it possible to share your solution? Thank you in advance
Users browsing this forum: Bing [Bot], Bytespider, ChatGPT-User, PerplexityBot, PetalBot and 1 guest
