Rust driving 64x32 HUB75 display on ESP32-C3
Posted: Sun Feb 11, 2024 12:14 am
by spluko
I'm trying to talk to a 64x32 pixel RGB LED display with a HUB75 interface from an ESP32-C3 using I2S and DMA. Basically I want to port this C code to Rust: https://github.com/ESP32DE/I2S_parallel ... app_main.c.
This uses the I2S in parallel (aka LCD) mode, which doesn't seem to be exposed in esp32c3-hal (doesn't seem to be in esp32-hal either). Am I missing something or is this just not supported? Without this am I completely blocked, or is there some lower level access I can use?
Re: Rust driving 64x32 HUB75 display on ESP32-C3
Posted: Mon Feb 12, 2024 2:27 am
by Sprite
The ESP32-C3 does not have that mode. I don't think that chip really has many options to drive something like a HUB75 display, sorry.
Posted: Fri Feb 16, 2024 12:41 am
by spluko
Thanks so much for responding, ESP_Sprite, I see that you are the golden source on this topic as pretty much everything I find about talking to these devices from ESP32 references back to you. Sorry I didn't get back sooner, but it seems I have to manually subscribe to my own post to get notified about responses.
Which SOCs do support this, and more importantly, where should I find that information? I'd like to use Risk V, as that seems easier to set up in Rust.
Posted: Fri Feb 16, 2024 1:15 am
by Sprite
Conceptually, there are multiple chips that have something you can abuse. The ESP32 has the parallel I2S mode, the ESP32-S3 has the LCD controller peripheral and the ESP32-C6 has the PARLIO device. Given that the -C6 is a RiscV device, you may want to look at that first.
Posted: Fri Feb 16, 2024 6:19 pm
by spluko
Thanks, that looks like a nice clean approach, and PARLIO is already exposed in Rust. I'll order a couple of devboards now. I'm also looking at trying the PIO on the RP2040, as that seems pretty cool. We'll see which works out better.
Posted: Sat Jun 21, 2025 1:23 pm
by liebman
I know its a bit late but I've recently published a no-std crate that drives Hub75 Displays for ESP32, ESP32S3 and ESP32C6.
https://crates.io/crates/esp-hub75
