esp32-H2 timer reboot forever
ZodiacGSK
Postby ZodiacGSK » Mon Feb 19, 2024 12:10 am
I have a problem, i'm using an esp32-H2 devkit and i made a simple program to make a chrono with a timer (i'm using the 3.0.0 alpha Arduino core, they changed the timer library). The problem is that if i put this line :(timerAttachInterrupt(timer, &AddSecondTimer);), i got this in the console in loop :
Code: log.txt Select all
ESP-ROM:esp32h2-20221101
Build:Nov 1 2022
rst:0xc (SW_CPU),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x400031b6
SPIWP:0xee
mode:DIO, clock div:1
load:0x4083cfd0,len:0xb68
load:0x4083efd0,len:0x2718
load:0x408460e8,len:0x590
entry 0x4083cfd0
Initialization (0%)
Guru Meditation Error: Core 0 panic'ed (Load access fault). Exception was unhandled.
Core 0 register dump:
MEPC : 0x42001972 RA : 0x42000042 SP : 0x408146d0 GP : 0x4080bd60
TP : 0x4080896c T0 : 0x400184be T1 : 0x77270000 T2 : 0x00000000
S0/FP : 0x00000000 S1 : 0x00000000 A0 : 0x00000000 A1 : 0x40800258
A2 : 0x00000000 A3 : 0xfffffffd A4 : 0x0020001f A5 : 0x4080025a
A6 : 0xfbdf0000 A7 : 0x000000fb S2 : 0x00000000 S3 : 0x00000000
S4 : 0x00000000 S5 : 0x00000000 S6 : 0x00000000 S7 : 0x00000000
S8 : 0x00000000 S9 : 0x00000000 S10 : 0x00000000 S11 : 0x00000000
T3 : 0x4084e530 T4 : 0x00000000 T5 : 0x00000000 T6 : 0x00000000
MSTATUS : 0x00001881 MTVEC : 0x40800001 MCAUSE : 0x00000005 MTVAL : 0x0000000c
MHARTID : 0x00000000
Stack memory:
408146d0: 0x00000000 0x4080c5b0 0x00000000 0x4080025a 0x00000000 0x00000000 0x00000000 0x4200002e
408146f0: 0x00000000 0x00000000 0x00000000 0x42002544 0x00000000 0x00000000 0x00000000 0x00000000
40814710: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5
40814730: 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xbaad5678 0x00038c35 0x4080dbe4 0x4080dbe4
40814750: 0x2a40c24e 0xb5f82a4e 0x623ddc8d 0x83d6d812 0x253eb1d0 0x893576c2 0xfb0d9ab7 0xc70964f5
40814770: 0x41077229 0xeb94c6be 0xfdaf2cdb 0xbde1ed95 0x331ab35c 0xb0cf0919 0xc913d8c6 0xf290ca77
40814790: 0x2617a9dc 0x3262cc32 0xa3c46155 0x83a5ce1c 0x469de453 0x30088b5e 0x6d8f8a66 0x9df5a2ac
408147b0: 0x9d9bcc26 0x5b6592e6 0x07196bd6 0xdd7103b6 0x9a9c0c32 0x824601e1 0x94372a63 0x1cc258e1
408147d0: 0x8c7129e4 0xebd88e2a 0xb53b37e7 0x8aa8aaf1 0xa1676ae8 0x4db5715d 0xedadbae1 0x29854fd0
408147f0: 0xc175e726 0x5ba84343 0x9c68fbfb 0x70424984 0xc927b543 0xa833ae79 0xba66579b 0x27e762e8
40814810: 0x1c37b1dd 0xa44c2aab 0xf826a6b8 0x48f88a3f 0xf9b4edf9 0xdd8352c4 0xbf4490b8 0x623b46d1
40814830: 0x2e225854 0x343f4a1e 0x66a52879 0x8a85b676 0x6c8f1f2e 0x13e4b6cd 0x9cd68807 0x1bb9b0bb
40814850: 0xb7eccdfe 0xd20fe7d3 0xec9e7bdf 0x7e74e56e 0x9eab1673 0xa0ce8c71 0x12eee1dc 0xcee38452
40814870: 0x3170e725 0x49de1828 0xa5bf2d24 0x87807879 0xad450068 0x864fc28a 0x64f84e35 0xdcdd15dd
40814890: 0xa4071a44 0x0aade563 0x1c489ea6 0x8a57b0ce 0x3be7b880 0x25b889c6 0xd8144dc8 0xd3044e8b
408148b0: 0x05e3898a 0x1e8d4557 0xc461af7a 0xa7c76255 0x4eed4efb 0x2e1c6ac7 0xf15ef47f 0x3b6fe5d5
408148d0: 0x06b5cad3 0x6e4520c7 0x24cf32bf 0x9f2de4b3 0x32095f44 0x321d8c48 0xb465a83f 0xfe3192bb
408148f0: 0x2eb17522 0x162a21ab 0x80f2fde9 0x29742d28 0x06d83094 0xaf9b84e0 0xdbf4c33e 0xf0eb92cd
40814910: 0x1031429d 0x4b8da38b 0x8cf109aa 0x6144fae0 0xce606e4f 0x9dcb69cc 0x6d1bfee4 0xbf1657a8
40814930: 0x186a1e67 0x11c388f1 0x16307a08 0x33cfc436 0x5600d049 0xdac44cf8 0x0b530643 0xfdec219c
40814950: 0x142c3b83 0xd5949d85 0xc4d5d7c8 0xeb241daa 0x4294eaa3 0x3a5fb0b1 0xc58ec621 0x43b43cb5
40814970: 0x07ff43be 0xd1389007 0xc04e760b 0x5f8f4b52 0x1e2098e8 0x285a0a99 0xe622dc10 0xc4b7671a
40814990: 0xb1e449d1 0x3450a7b2 0x1f539882 0x46d0e970 0x2af83dfc 0xb687f3a6 0xa3919615 0xf258827d
408149b0: 0xbbbbba08 0x00f51a91 0xd3d68d5a 0x2348b9aa 0x1e1c5ccb 0xd8b42c02 0xdf6a83b2 0x2fc022bd
408149d0: 0xe49923b9 0x2490b526 0xd634e8f0 0xd5f33809 0xf9ec43fd 0xdf12348f 0x874fd1c2 0x1332aa7c
408149f0: 0x1cb5d1c5 0xc44c9ca2 0x6187d5ff 0x3f3779b5 0x90f5b36a 0x87774caa 0xa0fb1507 0xbcb64bd1
40814a10: 0x53254eba 0x9ccba018 0x63bea8b2 0x9792971d 0x1bf2504f 0xd65e1921 0xd26eb63c 0x4cf378ce
40814a30: 0x31bf4733 0x52d174a5 0xae0ffa42 0x54491b1b 0x3ac201ca 0xaa65c8d0 0x6a667faf 0x66ba8f1a
40814a50: 0x672366f2 0x911f57ea 0xebbc3ff2 0x1c447ae9 0x0bde6484 0x770af7fb 0xb278a79f 0x1d23c290
40814a70: 0x41285dee 0x209ddb4e 0xa0d10b3d 0x2478d472 0x82e499f3 0xa9592098 0x0dfa111c 0x71ee1897
40814a90: 0x26553823 0x981cac89 0x32a0f6c7 0x6f188415 0x6e961415 0x7e13b72b 0x0f9e4ece 0xf7234ac6
40814ab0: 0xaed40f06 0xaa05efe5 0xcd1cfb5d 0x70c2ddaa 0xc1bf09bb 0x3e2e5321 0xfa8eeb62 0x8adce929
ELF file SHA256: d383a8f0b1ac7154
Rebooting...
Here is the full code :
Code: MyCode.cpp Select all
hw_timer_t * timer = NULL;
void IRAM_ATTR AddSecondTimer()
Serial.println("Tick");
void PauseChrono()
// Let's try to make this code work before
void SetupTimer()
timer = timerBegin(80);
// timerAttachInterrupt(timer, &AddSecondTimer);
// timerAlarm(timer, 1000000, true, 0);
Serial.println("Initialization (100%)");
Serial.println("---------------------");
void setup()
Serial.println("-------------------");
Serial.println("Initialization (0%)");
SetupTimer();
void loop()
//empty
I'm a student and i'm not experienced, so it's maybe something really simple to resolve. Also if i put a value of 1000 or more to timerBegin(), no more error but AddSecondTimer() is never called.
Re: esp32-H2 timer reboot forever
Postby Sprite » Mon Feb 19, 2024 3:25 am
I think the issue us that you cannot call that code from an ISR.
ZodiacGSK
Postby ZodiacGSK » Mon Feb 19, 2024 12:56 pm
So i tried changing the code and the problem still the same. I tried event without anything in AddSecondTimer, and same problem. I looked about this on internet
Code: Untitled.txt Select all
, and people say it's maybe a "heap corruption". Here is the library behind
Code: esp32-hal-timer.h.cpp Select all
Arduino.h - Main include file for the Arduino SDK
Copyright (c) 2005-2013 Arduino Team. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#pragma once
#include "soc/soc_caps.h"
#if SOC_GPTIMER_SUPPORTED
#include "esp32-hal.h"
#include "driver/gptimer_types.h"
#ifdef __cplusplus
extern "C" {
#endif
struct timer_struct_t;
typedef struct timer_struct_t hw_timer_t;
hw_timer_t * timerBegin(uint32_t frequency);
void timerEnd(hw_timer_t * timer);
void timerStart(hw_timer_t * timer);
void timerStop(hw_timer_t * timer);
void timerRestart(hw_timer_t * timer);
void timerWrite(hw_timer_t * timer, uint64_t val);
uint64_t timerRead(hw_timer_t * timer);
uint64_t timerReadMicros(hw_timer_t * timer);
uint64_t timerReadMilis(hw_timer_t * timer);
double timerReadSeconds(hw_timer_t * timer);
uint32_t timerGetFrequency(hw_timer_t * timer);
void timerAttachInterrupt(hw_timer_t * timer, void (*userFunc)(void));
void timerAttachInterruptArg(hw_timer_t * timer, void (*userFunc)(void*), void * arg);
void timerDetachInterrupt(hw_timer_t * timer);
void timerAlarm(hw_timer_t * timer, uint64_t alarm_value, bool autoreload, uint64_t reload_count);
#ifdef __cplusplus
#endif
#endif /* SOC_GPTIMER_SUPPORTED */
Any idea of what i'm doing wrong ?
ZodiacGSK
Postby ZodiacGSK » Mon Feb 19, 2024 2:22 pm
I found the documentation for this version (https://docs.espressif.com/projects/ard ... timer.html) and even the exemple is not working.
Code: Untitled.cpp Select all
Repeat timer example
This example shows how to use hardware timer in ESP32. The timer calls onTimer
function every second. The timer can be stopped with button attached to PIN 0
(IO0).
This example code is in the public domain.
// Stop button is attached to PIN 0 (IO0)
#define BTN_STOP_ALARM 0
volatile SemaphoreHandle_t timerSemaphore;
portMUX_TYPE timerMux = portMUX_INITIALIZER_UNLOCKED;
volatile uint32_t isrCounter = 0;
volatile uint32_t lastIsrAt = 0;
void ARDUINO_ISR_ATTR onTimer(){
// Increment the counter and set the time of ISR
portENTER_CRITICAL_ISR(&timerMux);
isrCounter = isrCounter + 1;
lastIsrAt = millis();
portEXIT_CRITICAL_ISR(&timerMux);
// Give a semaphore that we can check in the loop
xSemaphoreGiveFromISR(timerSemaphore, NULL);
// It is safe to use digitalRead/Write here if you want to toggle an output
// Set BTN_STOP_ALARM to input mode
pinMode(BTN_STOP_ALARM, INPUT);
// Create semaphore to inform us when the timer has fired
timerSemaphore = xSemaphoreCreateBinary();
// Set timer frequency to 1Mhz
timer = timerBegin(1000000);
// Attach onTimer function to our timer.
timerAttachInterrupt(timer, &onTimer);
// Set alarm to call onTimer function every second (value in microseconds).
// Repeat the alarm (third parameter) with unlimited count = 0 (fourth parameter).
// If Timer has fired
if (xSemaphoreTake(timerSemaphore, 0) == pdTRUE){
uint32_t isrCount = 0, isrTime = 0;
// Read the interrupt count and time
portENTER_CRITICAL(&timerMux);
isrCount = isrCounter;
isrTime = lastIsrAt;
portEXIT_CRITICAL(&timerMux);
// Print it
Serial.print("onTimer no. ");
Serial.print(isrCount);
Serial.print(" at ");
Serial.print(isrTime);
Serial.println(" ms");
// If button is pressed
if (digitalRead(BTN_STOP_ALARM) == LOW) {
// If timer is still running
if (timer) {
// Stop and free timer
timerEnd(timer);
timer = NULL;
I'm lost, it's probably an option in my arduino IDE but i don't know which one could be responsible.
lbernstone
Postby lbernstone » Mon Feb 19, 2024 6:21 pm
Since you are using 3.0, you should use the example from 3.0. Setting the frequency to 80Hz should generate an error rather than a crash.
As Sprite_TM says, Serial.print is a bad idea in an ISR. Use ets_printf.
H2 is still experimental, and does have some issues with the clock timing. Open an issue on the repo if the unmodified example crashes.
If you don't need a high precision timer, Ticker is a much more forgiving method that doesn't use hardware interrupts.
Users browsing this forum: Baidu [Spider], Barkrowler and 3 guests
