I'm using this library on an esp32 wroom32d, 8mb.
https://github.com/sdp8483/ESP32-Arduino-CAN
I'm using it at 1mbit, and converting data to display on an LCD. Some data comes in quicker than others but it still feels like there is lag there compared to 500k.
My code in loop()
if (ESP32CAN_OK == ESP32Can.CANReadFrame(&rx_frame)) { /* only print when CAN message is received*/ processdata(rx_frame); }
processdata interprets the ID which tells it what data it is and displays it.
I'm stumped as to how to diagnose and am needing some help.
Esp32 canbus slow at 1mbit?
DrMickeyLauer
Re: Esp32 canbus slow at 1mbit?
Assuming you have already modified the most important performance settings for CAN (CPU speed max, tick clock 1000 and CAN irq handler in IRAM)… at CAN speeds, the impact of printing to UART is huge. I'd remove all printing code and just keep a packet counter, so you can measure how many packets per second you receive. Test that with different CAN speeds. Note that the Arduino abstraction might come with another performance hit, so you might want to cross-test with a pure ESP-IDF project.
That said, the CAN controller in the ESP32 family is based on a pretty old design. It has a tiny hardware buffer, so you really need to pick up your frames from the bus as fast as possible, otherwise you're losing them.
So I havent made any changes other than... as far as CPU speed, it should be 240mhz. I'm using PlatformIO and VSCode so I think by default when I selected the esp32 it had 240mhz setup.
When you're talking about IRAM, is it as simple as me adding IRAM_ATTR to my parsing logic? or do I need to do that before?
Tick clock - not sure where to check this.
DrMickeyLauer
IRAM for the CAN irq handler is two-fold, one is a setting in the sdkconfig, the other is when setting the TWAI flags in code. As you're using the Arduino abstraction, I'm not sure if this is done already. Tick clock to 1000 is another sdkconfig setting, but IIRC that's probably also default in Arduino.
Ok, so I went back to the miwagner version of the library and got it working at 1mbit. Messed with recieve buffers and it made a difference. Now I'm wondering where to update the rx_buffer on the new library that I referenced earlier...
Well, I reverted back to the ESP32CAN library:
there is still a delay. I updated the miwagner to work at 1000mbits but it also has the same issue. I am stumped as to where to debug.
I'm experimenting with TWAI_MODE_LISTEN_ONLY but when I do that I receive the same data over and over.
Siimsalabim
Hi, as it happens I am currently writing my Bachelor's thesis on CAN bus for home automation and ran into similar findings. So I had to make an account and join the conversationWell, I reverted back to the ESP32CAN library:
- speed_vs_time.png (57.42 KiB) Viewed 4359 times
