Canceled Project
Posted: Thu Dec 07, 2017 3:56 pm
by enitalp
So my project go canceled and will not make it to marked. Time to share some goodies.
V1 was, Sparkfun and or Adafruit, Some sparkfun RGB Modiule MFRC522 RFID then and CLRC663b RFID Deb board. And in my hand the first produced V2
V1 vs V2.JPG (867.9 KiB) Viewed 11888 times
V2 (on right) Was using an esp wroom and added an Lp55231 for leds and an Clrc663 vs V3 (on left)No FTTDI it as a cable from outside
V2 vs V3.JPG (769.96 KiB) Viewed 11888 times
Back side of V2
Re: Canceled Project
Posted: Thu Dec 07, 2017 4:06 pm
by enitalp
V3
V3 also integrated the USE_MMA9553 And FTDI was back on board
Proto V3.JPG (56.2 KiB) Viewed 11886 times
Proto V3-2.JPG (811.66 KiB) Viewed 11886 times
Posted: Thu Dec 07, 2017 4:13 pm
by enitalp
V4 replaced the MMA9553 for a KX126 ( to add tap and double tap support)
Plus the board size should have been almost the final one.
FTTDI and power, and charging was in a dock outside the wearable
The board
V4 DSC_0034.JPG (469.88 KiB) Viewed 11884 times
Folding with the battery to gon in the box
V4 DSC_0039.JPG (448.22 KiB) Viewed 11884 times
And the box prototype
V4 DSC_0064.JPG (537.44 KiB) Viewed 11884 times
Posted: Fri Dec 08, 2017 12:52 am
by rudi ;-)
hi
thanks for share.
what happens?
why goes it canceled and not make it to marked?
please tell more about.
Posted: Fri Dec 08, 2017 10:40 pm
by enitalp
Hi.
For a lot of reason.
The harware what not the main product, just an add on. We are video game maker. upper management feared the price of the hardware in stock if the game doesn't sell.
Posted: Sat Dec 09, 2017 12:57 am
by rudi ;-)
Hi
thanks.
do you think there are alternatives for the add on and you can give the project a chance?
can you speak about? perhabs we can find out in the community a solution for a try?
are you on twitter?
FYI, you are not allone - some people want know more about the project, it looks from begin to the V4 very detailed and perhabs helps drum up funding? what you mean?
that would be without risk but nevertheless an attempt to bring the work and effort on the market
is the upper management ready to talk for this try?
the work is very detailed and and thoughtful.
and I think you deserve it
good work!
(btw: I would take the blue and the white)
