ESP-IDF documentation says use settimeofday() to set the RTC.
"To stop smooth time adjustment and update the current time immediately, use the POSIX function settimeofday()."
When I compile IDE (VSC) says settimeofday() not declared. Is there a library I need?
settimeofday() not working
dandydan51
Re: settimeofday() not working
Thank you. #include <sys/time.h> worked.
I have found no mention of sys/time.h anywhere in ESP-IDF documentation or examples. Where should I have found this information?
MicroController
https://docs.espressif.com/projects/esp ... rrent-time:
i.e. it's not an IDF function; that's why it's not specifically documented with the IDF.use the POSIX function settimeofday().
(https://linuxhint.com/gettimeofday-settimeofday-c/)The settimeofday () function is a standard function whose definition is mentioned in a header file in the C library named sys/time.h
Users browsing this forum: Qwantbot and 5 guests
