rst:0x1 (POWERON_RESET),boot:0x3
Posted: Sun Mar 03, 2024 2:07 pm
by longerski
Hello.
I am trying to upload a program to ESP-Wroom-32D. I connect 3.3V, GND, RX and TX. I get into download mode (GND-GPI0) but the console says: 'rst:0x1 (POWERON_RESET),boot:0x1'
But it should be: 'rst:0x1 (POWERON_RESET),boot:0x3'
Where am I making mistake?
Thanks.
Re: rst:0x1 (POWERON_RESET),boot:0x3
Posted: Mon Mar 04, 2024 2:31 am
by Sprite
The level of the GPIO15/MTDO pin is low in your hardware while it is high in the 0x3 boot line. You should still be able to flash the ESP32, whatever the level of that pin is.
Posted: Mon Mar 04, 2024 9:33 am
by longerski
Unfortunately I can't connect to esp, no flashing.
Connecting........... and end.
Posted: Tue Mar 05, 2024 12:47 am
by Sprite
I'd suggest you check the Tx line from your serial port or USB-serial converter to the Rx of the ESP32 in that case. If that's faulty, you can't get a connection.
