ESP-IDF Compiler Errors
jimmyvongjv
Postby jimmyvongjv » Thu Mar 14, 2024 2:12 pm
I am having some errors when trying to build my code. I've been editing some code on visual studio using the Espressif extension for the past two weeks without any error. But today, I am running into some errors out of no where after making no changes to my code. One reason this could potentially be happening is that I updated my windows laptop at the end of the day yesterday and it could have corrupted something but I have already tried reinstalling ESP-IDF and visual studio itself as well. I have also tried using other versions of ESP-IDF but this hasn't solved the issue either. I am currently using ESP-IDF v5.2.1. Here are the error logs I am having.
Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
Compiler: C:/Users/Jimmy/.espressif/tools/xtensa-esp-elf/esp-13.2.0_20230928/xtensa-esp-elf/bin/xtensa-esp32-elf-g++.exe
Build flags: -mlongcalls;-Wno-frame-address;
Id flags:
The output was:
Exit code 0xc0000142
Detecting CXX compiler ABI info failed to compile with the following output:
Change Dir: C:/Users/Jimmy/ESP32/TESSTING_GIMBLE/build/CMakeFiles/CMakeTmp
Run Build Command(s):C:/Users/Jimmy/.espressif/tools/ninja/1.11.1/ninja.exe cmTC_ba132 && [1/2] Building CXX object CMakeFiles/cmTC_ba132.dir/CMakeCXXCompilerABI.cpp.obj
FAILED: CMakeFiles/cmTC_ba132.dir/CMakeCXXCompilerABI.cpp.obj
C:\Users\Jimmy\.espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address -v -o CMakeFiles/cmTC_ba132.dir/CMakeCXXCompilerABI.cpp.obj -c C:/Users/Jimmy/.espressif/tools/cmake/3.24.0/share/cmake-3.24/Modules/CMakeCXXCompilerABI.cpp
Determining if the CXX compiler works failed with the following output:
Run Build Command(s):C:/Users/Jimmy/.espressif/tools/ninja/1.11.1/ninja.exe cmTC_efcd0 && [1/2] Building CXX object CMakeFiles/cmTC_efcd0.dir/testCXXCompiler.cxx.obj
FAILED: CMakeFiles/cmTC_efcd0.dir/testCXXCompiler.cxx.obj
C:\Users\Jimmy\.espressif\tools\xtensa-esp-elf\esp-13.2.0_20230928\xtensa-esp-elf\bin\xtensa-esp32-elf-g++.exe -mlongcalls -Wno-frame-address -o CMakeFiles/cmTC_efcd0.dir/testCXXCompiler.cxx.obj -c C:/Users/Jimmy/ESP32/TESSTING_GIMBLE/build/CMakeFiles/CMakeTmp/testCXXCompiler.cxx
arrell
Re: ESP-IDF Compiler Errors
Postby arrell » Sun Aug 18, 2024 9:14 am
Were you able to you resolve this?
jimmyvongjv
Postby jimmyvongjv » Mon Aug 26, 2024 12:32 pm
I ended up resetting my laptop with the keep files selection and it ended up fixing the problem.
Users browsing this forum: PerplexityBot and 8 guests
