Data Transfer Using Wi-Fi Direct with ESP32 and Establishing Wi-Fi Direct Connection between ESP32 and Android Phone
Posted: Mon Mar 18, 2024 7:37 am
by sema11
Hello! I want to transfer data between two ESP32 devices using Wi-Fi Direct. I couldn't find definitive information about whether ESP32 supports Wi-Fi Direct feature. Below, I am doing data transfer using one slave and one master, but I can't understand if this is Wi-Fi Direct or not. Because according to this, I want to use Wi-Fi Direct between an ESP32 and an Android phone later. Is it possible for me to do this? I would be very happy if you could help. Thank you in advance.
//SLAVE KODLARI
#include <ArduinoWebsockets.h>
#include <WiFi.h>
#include <SD.h> // SD kütüphanesini dahil edin
#include "SD.h"
#include "SPI.h"
#include "FS.h"
const char* ssid = "wifidirect_test";
const char* password = "12345678";
const char* websockets_server_host = "192.168.4.1";
const uint16_t websockets_server_port = 8888;
using namespace websockets;
WebsocketsClient client;
const int chipSelect = 5; // SD kartın kullanacağı pin
File dataFile;
void setup() {
  Serial.begin(115200);
  pinMode(5,INPUT);
  digitalWrite(5,HIGH);
  Serial.setDebugOutput(true);
  Serial.println();
  // Connect to wifi
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("Socket Connecting");
  while(!client.connect(websockets_server_host, websockets_server_port, "/")){
    delay(500);
    Serial.print(".");
  Serial.println("Socket Connected!");
  // SD kartı başlat
  if(!SD.begin(5)){        //SD kart baslatilir
  if (!SD.begin(true)) {
  //Serial.println("An Error has occurred while mounting SD");
void loop() {
  dataFile = SD.open("/data.txt"); // Okunacak dosyayı açın
  if (dataFile) {
    String data = dataFile.readStringUntil('\n');  // Dosyadan bir satır okuyun
    client.sendBinary(data); // Veriyi master'a gönderin
  if (!dataFile.available()) {
    // Dosya sonuna gelindiğinde tekrar başa alın
    dataFile.close();
  delay(1000); // Gönderimler arasında bekleme süresi
//MASTER
#include <WiFi.h>
#include "SD.h"
#include "SPI.h"
#include "FS.h"
WebsocketsServer server;
void setup() {
  //Connect to wifi
  WiFi.softAP(ssid, password);
  server.listen(8888);
void loop() {
  if(server.poll()){
    client = server.accept();
    Serial.println("Bağlantı");
  if(client.available()){
    client.poll();
   uint32_t messageReceivedTime = millis();
    WebsocketsMessage msg = client.readBlocking();
    Serial.println("Mesaj uzunluğu: ");
    Serial.println(msg.length());
    Serial.println("Mesaj: ");
    Serial.println(msg.c_str());
      uint32_t elapsedTime = millis() - messageReceivedTime;
  Serial.print("Mesaj alındığı süre: ");
  Serial.println(elapsedTime);
Re: Data Transfer Using Wi-Fi Direct with ESP32 and Establishing Wi-Fi Direct Connection between ESP32 and Android Phone
Posted: Thu Jan 01, 2026 9:48 am
by AndrewWang
This is not WiFi-Direct. One method to determine if you are using WiFi-Direct is that if your phone need to disconnect its WiFi and then connect your ESP device, it's not through WiFi direct. WiFi direct won't conflict with WiFi STA/AP.
Actually ESP-IDF doesn't support WiFi-Direct till now.
So I'm trying to implement this function by myself. If you need WiFi direct, you can follow this repository and post me some advice or issue.
https://github.com/AHWang2/ESP-WiFi-P2P-WiFi-Direct
