[FreeRTOS] How to use paho mqtt with MQTTFreeRTOS sources ?
Arkaik
Postby Arkaik » Tue Dec 12, 2017 7:09 pm
I'm using Kolban's esp32 port available here https://github.com/nkolban/esp32-snippe ... embedded_c
Everything compile fine and I'm able to publish into my topics on my remote MQTT server.
However after some time (around 5 minutes) I don't receive messages anymore. I investigated a little into paho sources and I realized that MQTTFreeRTOS.h is never included nor used anywhere when using MQTTClient-C.
$ rgrep -n MQTTFreeRTOS.h
components/paho_mqtt_embedded_c/MQTTClient-C/src/FreeRTOS/MQTTFreeRTOS.c:18:#include "MQTTFreeRTOS.h"
Indeed high-level MQTTClient include linux sources but not freeRTOS ones.
MQTTClient.h
 * Copyright (c) 2014, 2015 IBM Corp.
 * All rights reserved. This program and the accompanying materials
 * are made available under the terms of the Eclipse Public License v1.0
 * and Eclipse Distribution License v1.0 which accompany this distribution.
 * The Eclipse Public License is available at
 *    http://www.eclipse.org/legal/epl-v10.html
 * and the Eclipse Distribution License is available at
 *   http://www.eclipse.org/org/documents/edl-v10.php.
 * Contributors:
 *    Allan Stockdill-Mander/Ian Craggs - initial API and implementation and/or initial documentation
 *    Ian Craggs - documentation and platform specific header
#if !defined(__MQTT_CLIENT_C_)
#define __MQTT_CLIENT_C_
#if defined(__cplusplus)
 extern "C" {
#endif
#if defined(WIN32_DLL) || defined(WIN64_DLL)
  #define DLLImport __declspec(dllimport)
  #define DLLExport __declspec(dllexport)
#elif defined(LINUX_SO)
  #define DLLImport extern
  #define DLLExport  __attribute__ ((visibility ("default")))
#else
  #define DLLImport
  #define DLLExport
#endif
#include "MQTTLinux.h"
#include "MQTTPacket.h"
#include "stdio.h"
#if defined(MQTTCLIENT_PLATFORM_HEADER)
/* The following sequence of macros converts the MQTTCLIENT_PLATFORM_HEADER value
 * into a string constant suitable for use with include.
#define xstr(s) str(s)
#define str(s) #s
#include xstr(MQTTCLIENT_PLATFORM_HEADER)
#endif
So to use MQTT FreeRTOS sources I replaced
with
However I've got the following error when compiling
$ make
CC MQTTClient-C/src/MQTTClient.o
In file included from <project_path>/components/paho_mqtt_embedded_c/MQTTClient-C/src/MQTTClient.h:35:0,
                 from <project_path>/components/paho_mqtt_embedded_c/MQTTClient-C/src/MQTTClient.c:16:
<project_path>/components/paho_mqtt_embedded_c/MQTTClient-C/src/FreeRTOS/MQTTFreeRTOS.h:20:22: fatal error: FreeRTOS.h: No such file or directory
compilation terminated.
<esp-idf_path>/make/component_wrapper.mk:202 : la recette pour la cible « MQTTClient-C/src/MQTTClient.o » a échouée
make[1]: *** [MQTTClient-C/src/MQTTClient.o] Erreur 1
<esp-idf_path>/make/project.mk:386 : la recette pour la cible « paho_mqtt_embedded_c-build » a échouée
make: *** [paho_mqtt_embedded_c-build] Erreur 2
The linker doesn't seems to be able to find freertos directory. Indeed in my main app I use the following includes
#include <esp_wifi.h>
#include <freertos/FreeRTOS.h>
#include <freertos/event_groups.h>
#include <lwip/sockets.h>
#include <nvs_flash.h>
#include "driver/i2c.h"
When paho uses the following one
#include "FreeRTOS.h"
#include "FreeRTOS_Sockets.h"
#include "FreeRTOS_IP.h"
#include "semphr.h"
#include "task.h"
The header is in freertos path, however I don't want to modify all the paho sources to use the same include format.
How can I include freertos directory without having to modify esp-idf makefiles ?
Is that normal that paho doesn't use MQTTFreeRTOS.h by default ? Or at least is surrounded with #ifdef #endif to use freeRTOS sources when deployed on freeRTOS ?
Am I doing the good thing to use freeRTOS paho sources instead of linux ones ?
Moreover, I also realized that FreeRTOS.h is including files that doesn't exit on my computer, so external sources which are FreeRTOS_Sockets.h FreeRTOS_IP.h.
Where can I find those files ?
Thanks in advance
Gfast2
Re: [FreeRTOS] How to use paho mqtt with MQTTFreeRTOS sources ?
Postby Gfast2 » Wed Dec 13, 2017 4:27 am
Hi Arkaik,
AFAIK FreeRTOS has its own IP stack, which is not cost free. So in ESP-IDF we use lwIP.
The included header you mensioned in the library looks like from the FreeRTOS stack but not lwIP. I just tell you want I think, but still not googling around about them. Perhaps it helps.
BTW, I have spent nearly half year to port a another library Open62541 (OPC UA protocol) to ESP-IDF. Its really not that simple as I expacted. But I've learned tons of stuff meanwhile.
Cheers
Gfast2
Arkaik
Postby Arkaik » Wed Dec 13, 2017 10:40 am
Hi Gfast2,
In fact, I'm using lwIP to handle the wifi connection. I'm using the same method than for the example here : https://github.com/nkolban/esp32-snippe ... ple/main.c
My question is about low-level implementation of Timer and Network structures which MQTTClient-C uses.
You can see that both MQTTLinux.h and MQTTFreeRTOS.h are quite similar even if having differences. However MQTTFreeRTOS.h is never used or included anywhere so my question is : Why would there be a MQTTFreeRTOS.h if never used?
What I understand is I can either use MQTTLinux.h, MQTTCC3200.h or MQTTFreeRTOS.h depending on the targetted board/OS. Mine is ESP32DevKitC with FreeRTOS so I need to use MQTTFreeRTOS.h right ?
Now if I'm right I just don't understand how to integer paho using MQTTFreeRTOS.h (it works with linux one) because it's using headers that are not in the project architecture, so maybe I can find those external sources somewhere else but I'm surprised that it's using "out-of-project" files.
From what you say I could not use FreeRTOS IP stack because it's not cost free ? So why is this project using this IP stack instead of lwIP?
Thanks for your answer.
Gfast2
Postby Gfast2 » Wed Dec 13, 2017 11:36 am
I believe make FreeRTOS and lwIP works together just you've see on our ESP32s are also not easy. :lol:
bcanustundag
Postby bcanustundag » Wed Dec 13, 2017 11:49 am
Hi Arkaik,
For what it's worth, there is an example mqtt client implementation which employs esp32's tcp/ip socket implementation ( uses lwip of esp32-idf).
It can be the case that you've already seen it but here it is: https://github.com/tuanpmt/espmqtt
Baris
Arkaik
Postby Arkaik » Wed Dec 13, 2017 12:26 pm
Damn, so you think the port has only be done for Linux and not for FreeRTOS ?
I though all the development libraries were given with esp-idf, so you mean that FreeRTOS wifi stack is not given by esp-idf and I should find it somewhere else and integrate it to my project ?
Can you give me some advices on how I could go further ?
I find strange that nobody ever used MQTT for FreeRTOS on ESP32...
WiFive
Postby WiFive » Wed Dec 13, 2017 12:53 pm
nkolban just grabbed paho sources, modified Linux version to work with esp32 because esp32 has socket api wrapper for lwip. then he left the rest of the paho files there even if they are not needed.
Gfast2
Postby Gfast2 » Wed Dec 13, 2017 2:07 pm
Kolban is incredible, He is trying to do REALLY the advanced things! Highly respect!
It would be much cooler if some of us can make tutorials about these things, or just make very nice README, or just somehow make them cleaner. But I do understand, if I've got these library up'n running, I would not have enough power/time to make them that perfect...
Cheers
Gfast2
vonnieda
Postby vonnieda » Thu Dec 14, 2017 2:38 am
The AWS IOT component that comes with ESP-IDF includes paho and a working port. It has some bits in there to allow it to work with AWS IOT but the code is pretty close to what is needed to use paho by itself.
You can find the interesting bits at https://github.com/espressif/esp-idf/tr ... s_iot/port
Jason
kurtzweber
Postby kurtzweber » Thu Dec 14, 2017 1:31 pm
Baris
+1, I found this tutorial that describes how to use that library... for me it works fine!
http://www.lucadentella.it/en/2017/12/0 ... qtt-e-ssl/
Users browsing this forum: Bytespider, meta-externalagent, Perplexity-User, Qwantbot and 8 guests
