ESP32-S3 Flash Download Tool Error: NO XMC flash detected!
Jonathan2892
Postby Jonathan2892 » Wed Apr 10, 2024 1:31 pm
We want to use the esp32 flash download tool to flash our esp32-s3 based modules with the firmware for production.
I can flash the firmware via VS-code + espressif-extension without any problems.
But when I use the Flash Download Tool to write the firmware onto the esp32-s3 it is not working.
I get the following output form the tool:
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 1152000
Changed.
SPI_BOOT_CRYPT_CNT 0
SECURE_BOOT_EN False
 is stub and send flash finish
The only thing that works with tool is to erase the flash. This is working perfectly.
How can I fix this?
Some Setup Infos:
- esp32-s3-wroom-1u-n16r8
- Esp32-s3 Flash Download Tool V3.9.6
- Using USB-Pins to do the firmware download via UART-protocol (I also tried USB protocol, but same problem)
Best
Jonathan2892
Re: ESP32-S3 Flash Download Tool Error: NO XMC flash detected!
Postby Jonathan2892 » Thu Apr 11, 2024 8:42 pm
Solved it. It was a mistake on my side. I did not choose the right files for flashing.
But the message
is still a little bit confusing, since all esp32-s3-wroom modules have XMC flash or not?
Best
Postby Sprite » Fri Apr 12, 2024 2:21 am
They have flash, but it's not necessarily manufactured by XMC.
jatkins2431
Postby jatkins2431 » Mon Jun 17, 2024 1:15 am
I'm having the same problem and am new to the flasher tool. I currently have the main.bin, partition_table.bin, and bootloader.bin selected. Are these correct? Thanks
jay_Lia
Postby jay_Lia » Thu Oct 24, 2024 4:08 am
it's correct, just notice the configuration of SPI flash. it is need to match the SPI flash configuration on your IDF.
Users browsing this forum: Baidu [Spider], Semrush [Bot] and 1 guest
