ESP32-S3-Korvo-2 V3.0在运行chinese_tts出现I2C写入和读取失败导致没有声音
Zapei2
Postby Zapei2 » Mon Apr 15, 2024 8:32 am
I (0) cpu_start: App cpu up.
I (583) esp_psram: SPI SRAM memory test OK
I (592) cpu_start: Pro cpu start user code
I (592) cpu_start: cpu freq: 240000000 Hz
I (592) cpu_start: Application information:
I (595) cpu_start: Project name: chinese_tts
I (601) cpu_start: App version: 1
I (605) cpu_start: Compile time: Apr 15 2024 12:54:42
I (611) cpu_start: ELF file SHA256: 9b472b7e79614053...
I (617) cpu_start: ESP-IDF: v5.1.1
I (622) cpu_start: Min chip rev: v0.0
I (627) cpu_start: Max chip rev: v0.99
I (632) cpu_start: Chip rev: v0.2
I (636) heap_init: Initializing. RAM available for dynamic allocation:
I (643) heap_init: At 3FC9CFC8 len 0004C748 (305 KiB): DRAM
I (650) heap_init: At 3FCE9710 len 00005724 (21 KiB): STACK/DRAM
I (656) heap_init: At 600FE010 len 00001FD8 (7 KiB): RTCRAM
I (663) esp_psram: Adding pool of 8192K of PSRAM memory to heap allocator
I (671) spi_flash: detected chip: gd
I (674) spi_flash: flash io: qio
I (678) sleep: Configure to isolate all GPIO pins in sleep state
I (685) sleep: Enable automatic switching of GPIO sleep configuration
I (692) app_start: Starting scheduler on CPU0
I (697) app_start: Starting scheduler on CPU1
I (697) main_task: Started on CPU0
I (707) esp_psram: Reserving pool of 32K of internal memory for DMA/internal allocations
I (717) main_task: Calling app_main()
E (717) I2C_If: Fail to write to dev 80
E (727) I2C_If: Fail to write to dev 80
E (737) I2C_If: Fail to write to dev 80
E (747) I2C_If: Fail to write to dev 80
E (757) I2C_If: Fail to write to dev 80
E (757) ES7210: Write register fail
E (767) ES7210: Open fail
I (767) I2S_IF: channel mode 0 bits:32/32 channel:2 mask:3
I (777) I2S_IF: STD Mode 0 bits:32/32 channel:2 sample_rate:16000 mask:3
I (777) Adev_Codec: Open codec device OK
E (787) I2C_If: Fail to write to dev 30
E (797) I2C_If: Fail to write to dev 30
E (807) I2C_If: Fail to write to dev 30
E (817) I2C_If: Fail to write to dev 30
E (827) I2C_If: Fail to write to dev 30
E (837) I2C_If: Fail to read from dev 30
I (837) ES8311: Work in Slave mode
E (847) I2C_If: Fail to write to dev 30
E (857) I2C_If: Fail to read from dev 30
E (857) I2C_If: Fail to write to dev 30
E (867) I2C_If: Fail to write to dev 30
E (877) I2C_If: Fail to write to dev 30
E (877) ES8311: Open fail
I (887) I2S_IF: channel mode 0 bits:16/16 channel:2 mask:1
I (887) I2S_IF: STD Mode 1 bits:16/16 channel:2 sample_rate:16000 mask:1
I (897) Adev_Codec: Open codec device OK
ES7210和ES8311无法连接导致扬声器和麦克风都无法正常工作
