Cannot connect to WIFI
ZhengLinLei
Postby ZhengLinLei » Mon Apr 15, 2024 8:01 pm
I'm getting some troubles with my code trying to connect to one Wifi station. I tried changing everything, copied samples from everywhere and nothing worked. The hardware works correctly, because I tried the Arduino IDE Code and it worked
Code of the handler:
/* FreeRTOS event group to signal when we are connected*/
static EventGroupHandle_t s_wifi_event_group;
/* The event group allows multiple bits for each event, but we only care about two events:
 * - we are connected to the AP with an IP
 * - we failed to connect after the maximum amount of retries */
#define WIFI_CONNECTED_BIT BIT0
#define WIFI_FAIL_BIT      BIT1
static int s_retry_num = 0;
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
                                int32_t event_id, void* event_data)
    if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
        esp_wifi_connect();
    } else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
        if (s_retry_num < WIFI_ESP_MAXIMUM_RETRY) {
            esp_wifi_connect();
            s_retry_num++;
#ifdef VERBOSE
            printf("Retry to connect to the AP");
#endif
            xEventGroupSetBits(s_wifi_event_group, WIFI_FAIL_BIT);
#ifdef VERBOSE
        printf("Connect to the AP fail");
#endif
    } else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
        ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
#ifdef VERBOSE
        printf("Got ip:" IPSTR, IP2STR(&event->ip_info.ip));
#endif
        s_retry_num = 0;
        xEventGroupSetBits(s_wifi_event_group, WIFI_CONNECTED_BIT);
The connect function:
int wifi_connect(uint8_t* ssid, uint8_t* password) {
    nvs_flash_init();
    esp_wifi_init(&cfg);
    s_wifi_event_group = xEventGroupCreate();
    static wifi_config_t wifi_config = {
        .sta = {
            .ssid = "",
            .password = "",
    strcpy((char*)wifi_config.sta.ssid, (const char*)ssid); // copy chars from hardcoded configs to struct
    strcpy((char*)wifi_config.sta.password, (const char*)password);
#ifdef VERBOSE
    printf("SSID: %s\n", wifi_config.sta.ssid);
    printf("Password: %s\n", wifi_config.sta.password);
#endif
    esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, wifi_event_handler, NULL);
    esp_event_handler_register(IP_EVENT, IP_EVENT_STA_GOT_IP, wifi_event_handler, NULL);
    esp_wifi_set_mode(WIFI_MODE_STA);
    esp_wifi_set_config(ESP_IF_WIFI_STA, &wifi_config);
    esp_wifi_start();
    esp_wifi_connect();
#ifdef VERBOSE
    printf("Connecting to %s\n", ssid);
#endif
    EventBits_t bits = xEventGroupWaitBits(s_wifi_event_group, WIFI_CONNECTED_BIT | WIFI_FAIL_BIT, pdFALSE, pdFALSE, WIFI_ESP_CONN_TIMEOUT);
    esp_event_handler_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, wifi_event_handler);
    esp_event_handler_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, wifi_event_handler);
    if (bits & WIFI_CONNECTED_BIT) {
#ifdef VERBOSE
        printf("Connected to ssid:%s, password:%s\n", ssid, password);
#endif
        return 0;
    } else if (bits & WIFI_FAIL_BIT) {
#ifdef VERBOSE
        printf("Failed to connect to ssid:%s, password:%s\n", ssid, password);
#endif
        return 1;
#ifdef VERBOSE
        printf("Error connecting. Reset 0x00\n");
#endif
        return -1;
And the logs:
SSID: JM_limpia_el_baño
Password: LaTienesEnElRouter
Connecting to JM_limpia_el_baño
Function return: 2;
Any printf from wifi_event_handler are printed, I do not know if the problem is that I did not register the handler correctly or if I have something wrong in my code.
Thanks for helping me!!
I tried different version of codes from internet, ChatGPT, idf github and nothing worked :cry:
chegewara
Re: Cannot connect to WIFI
Postby chegewara » Tue Apr 16, 2024 6:14 pm
What is this value
mtraven
Postby mtraven » Tue Apr 16, 2024 10:19 pm
I'm going to assume you're usuing IDF ~5.2ish? please correct me if thats not the case, wifi is different in 4.4.7.
I struggled with this a few weeks ago, my advice:
up your log levels to at least debug, if not verbose. there is ALOT happening that you're not seeing in the logs with it set at INFO. You may find you want to turn off the verbose/debug for things other than wifi. you can do that with esp_log_level_set(tag, ESP_LOG_XXXX);
On that note, I recognize that #if (printf) style, I've used debugs like that for years. In some circumstances, I still do. You'd be wise to familiarize yourself with ESP_LOG(), it does everything you're doing, in a cleaner package. you write them the same as a printf (it uses printf), with a lead term "tag"--a const char* string. That categorizes your debug statements, both on screen & st you can manipulate levels of different things.
lastly, you're missing some stuff from your connect. Here is a file I made as a helper header (iNeedWifi.h) to get wifi. Its largley based on ESP examples, but not the example_connect() crap. do as you like with it. I'd compare your init stuff to mine, pay attention to the event loop & the config structure. My SSID and such as pulled from Kcofig, but you can define them directly the way you did in your code. at first glance, I didn't see these lines in your code:
 (esp_event_loop_create_default());
    esp_netif_create_default_wifi_sta();
did I miss them?
here is my code: NOTE: i dont initiated NVS with wifi, its assumed to already be initiated in the app, prior to calling
#ifndef INEEDWIFI_H
#define INEEDWIFI_H
 /// AUTH: MODE: (un comment 1 & put it in main with SSID & PASSWORD)
    // WIFI_AUTH_OPEN = 0,         /**< authenticate mode : open */
    //WIFI_AUTH_WEP,              /**< authenticate mode : WEP */
    //WIFI_AUTH_WPA_PSK,          /**< authenticate mode : WPA_PSK */
    //WIFI_AUTH_WPA2_PSK,         /**< authenticate mode : WPA2_PSK */
    //WIFI_AUTH_WPA_WPA2_PSK,     /**< authenticate mode : WPA_WPA2_PSK */
    //WIFI_AUTH_ENTERPRISE,       /**< authenticate mode : WiFi EAP security */
    //WIFI_AUTH_WPA2_ENTERPRISE = WIFI_AUTH_ENTERPRISE,  /**< authenticate mode : WiFi EAP security */
    //WIFI_AUTH_WPA3_PSK,         /**< authenticate mode : WPA3_PSK */
    //WIFI_AUTH_WPA2_WPA3_PSK,    /**< authenticate mode : WPA2_WPA3_PSK */
    //WIFI_AUTH_WAPI_PSK,         /**< authenticate mode : WAPI_PSK */
    //WIFI_AUTH_OWE,              /**< authenticate mode : OWE */
    //WIFI_AUTH_WPA3_ENT_192,     /**< authenticate mode : WPA3_ENT_SUITE_B_192_BIT */
    //WIFI_AUTH_WPA3_EXT_PSK,     /**< authenticate mode : WPA3_PSK_EXT_KEY */
    //WIFI_AUTH_WPA3_EXT_PSK_MIXED_MODE, /**< authenticate mode: WPA3_PSK + WPA3_PSK_EXT_KEY */
    //WIFI_AUTH_MAX
#include <string.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include "esp_wifi_types.h"
#include "esp_event.h"
#include "esp_log.h"
#include "nvs_flash.h"
#include "lwip/err.h"
#include "lwip/sys.h"
#define wifiTxPWR WIFI_POWER_5dBm
EventGroupHandle_t s_wifi_event_group; /* FreeRTOS event group to signal when we are connected*/
static const char *TAG_wifi = "my_wifi_sta";
/// prototyes: /////////////////////////
void event_handler(void* arg, esp_event_base_t event_base,int32_t event_id, void* event_data);
void wifi_init_sta(void);
void stopWifi();
void event_handler(void* arg, esp_event_base_t event_base, int32_t event_id, void* event_data)
        esp_wifi_connect();
        if (s_retry_num < MAXIMUM_RETRY)
            esp_wifi_connect();
            s_retry_num++;
            ESP_LOGW(TAG_wifi, "\n\n----------------------\n connect retry #%i \n------------------\n", s_retry_num);
        else
        ESP_LOGI(TAG_wifi,"connect to the AP fail");
        ESP_LOGI(TAG_wifi, "got ip:" IPSTR, IP2STR(&event->ip_info.ip));
        s_retry_num = 0;
void wifi_init_sta(void) //NVS ASSUMED TO BE INITITATED
    ESP_LOGW("TAG_wifi", "initiating wifi...");
    esp_event_handler_instance_t instance_any_id;
    esp_event_handler_instance_t instance_got_ip;
    ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
                                                        ESP_EVENT_ANY_ID,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_any_id));
    ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
                                                        &event_handler,
                                                        NULL,
                                                        &instance_got_ip));
        .sta = {
                .ssid = SSID,
                .password = WIFI_PASS,
                .scan_method= WIFI_FAST_SCAN,
                .channel=11,
                .threshold={.authmode = WIFI_AUTH_MODE},
                .sae_pwe_h2e = wifi_sae_pwe_method_t(WPA3_SAE_PWE_BOTH),
                .failure_retry_cnt=5,
                .sae_h2e_identifier = "",
    ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA) );
    ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config) );
    ESP_ERROR_CHECK(esp_wifi_start() );
    ESP_LOGI(TAG_wifi, "wifi_init_sta finished. ");
    /* Waiting until either the connection is established (WIFI_CONNECTED_BIT) or connection failed for the maximum
     * number of re-tries (WIFI_FAIL_BIT). The bits are set by event_handler() (see above) */
            pdFALSE,
            pdFALSE,
            portMAX_DELAY);
    /* xEventGroupWaitBits() returns the bits before the call returned, hence we can test which event actually
     * happened. */
        ESP_LOGI(TAG_wifi, "connected to ap SSID:%s password:%s",SSID, WIFI_PASS);
        ESP_LOGI(TAG_wifi, "Failed to connect to SSID:%s, password:%s",SSID, WIFI_PASS);
    else
        ESP_LOGE(TAG_wifi, "UNEXPECTED EVENT");
    /* The event will not be processed after unregister */
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(IP_EVENT, IP_EVENT_STA_GOT_IP, instance_got_ip));
    ESP_ERROR_CHECK(esp_event_handler_instance_unregister(WIFI_EVENT, ESP_EVENT_ANY_ID, instance_any_id));
    vEventGroupDelete(s_wifi_event_group);
void stopWifi()
     esp_wifi_disconnect();
#endif  // INEEDWIFI_H
Users browsing this forum: Applebot, Baidu [Spider], Qwantbot and 1 guest
