Correct order of API calls to become an access point ...
kolban
Postby kolban » Tue Nov 01, 2016 9:53 pm
When looking at the API to become an access point, I see that there are three APIs of interest:
  • esp_wifi_start()
  • esp_wifi_set_config(WIFI_IF_AP, ...)
  • esp_wifi_set_mode(WIFI_MODE_AP)
My question is ... What is the correct semantic sequence for calling these functions? Is there a "state diagram" for the WiFi engine that we should be using?
kolban
Re: Correct order of API calls to become an access point ...
Postby kolban » Wed Dec 28, 2016 1:49 am
*bump*
arao23
Postby arao23 » Fri Dec 30, 2016 10:38 pm
Set mode -> Set config -> Start works fine for me. After starting, I can switch between modes using just esp_wifi_set_mode without needing to touch anything else.
	ESP_ERROR_CHECK( esp_wifi_set_mode(WIFI_MODE_AP) );
	wifi_config_t apConfig = {
			.ap = {
					.ssid="SomeSSIDHere",
					.password = "SomePasswordMoreThan8Chars",
					.ssid_len = 0,
					.channel = 0,
					.authmode = WIFI_AUTH_WPA2_PSK,
					.ssid_hidden = 0,
					.max_connection = 4, // how many clients to allow?
					.beacon_interval = 100 // default value
	ESP_ERROR_CHECK( esp_wifi_set_config(WIFI_IF_AP, &apConfig) );
As for a state diagram, I'm not sure, but it would be quite helpful to have one that encompasses everything from start to finish, including when the various events are raised.
Users browsing this forum: Bing [Bot], Bytespider, PetalBot and 5 guests
