ESP32 WROOM 32E - GPIO 0 MCLK Signal Problems
Posted: Thu Apr 18, 2024 12:29 pm
by CCooper1971
I have designed a PCB using the ESP32 WROOM, after building a successful prototype. However, on the prototype, my GPIO 0 MCLCK signal is OK
I have designed the board using the Espressif reference diagram, also attached ESP32-DevKitC-V4_SCH_20180607A.pdf.
The reset and boot circuitry is identical and I have reviewed my PCB many times, cross referencing and cannot see any errors. I have also used this design previously and it works.
I am wondering if there is a firmware issue or difference on the ESP which is causing a conflict with GPIO 0?
Please note, that I am using the same code on both the prototype and the finished PCB and except for some pin changes, which I have also checked to ensure they do not cause a problem, they are the same.
// New Board
#define blueLED 25
#define greenLED 26
#define amberLED 12
#define redLED 15
#define blackButton 35
#define redButton 39
// Prototype Board
//#define greenLED 25
//#define amberLED 26
//#define redLED 12
//#define whiteLED 15
//#define blackButton 36
//#define redButton 39
Re: ESP32 WROOM 32E - GPIO 0 MCLK Signal Problems
Posted: Thu Apr 18, 2024 1:39 pm
by CCooper1971
Hi All,
For those who experience the same problem when using the reference designs, I have solved it as follows.
When reviewing the diagram supplied by Espressif, see initial post. C15, which is a 0.1uF debounce capacitor on the Boot switch causes, the MCLK to be smoothed. Upon removing said debounce capacitor, the MCLK signal works a treat, please see image.
My Class D I2S Amplifier Board now makes sound, hurrah!
Regards,
Christopher
