Get MAC address using espefuse
cskilbeck
Postby cskilbeck » Mon Apr 22, 2024 2:47 pm
Hi, I can get the MAC address using espefuse but it means extracting it from the output using sed or some similar pattern matching tool. This isn't ideal as the format of the output from espefuse isn't guaranteed. Is there a method to get the MAC address in a more defined way?
Thanks,
Charlie.
For reference, the output from espefuse summary contains this fragment:
MAC (BLOCK1)                                       MAC address
   = ec:da:3b:51:bb:a4 (OK) R/W
CUSTOM_MAC (BLOCK3)                                Custom MAC
   = 00:00:00:00:00:00 (OK) R/W
[/code]
liaifat85
Re: Get MAC address using espefuse
Postby liaifat85 » Mon Apr 22, 2024 3:54 pm
You can try the 'grep' and 'awk' commands.
cskilbeck
Postby cskilbeck » Mon Apr 22, 2024 4:07 pm
Sure, but unless the output format is guaranteed not to change then it could break when the espefuse tool is updated.
Postby Sprite » Tue Apr 23, 2024 12:40 am
espefuse is a Python script that you can also use as a library in your own Python scripts. Technically I don't think we promise anything about the API we provide there, but I imagine it's going to be more stable (and visible if it breaks) than parsing the output.
Roland
Postby Roland » Tue Apr 23, 2024 5:31 am
espefuse.py --port <PORT> summary --format value_only MAC
This will be supported from the upcoming v4.8 release of esptool.
Users browsing this forum: Bytespider, PetalBot, Qwantbot and 9 guests
