Not able to perform OTA using ESP32 with AWS S3
hi,
I am trying to run the https://github.com/espressif/esp-idf/tr ... _https_ota sample code to test the OTA over HTTPS, instead of web server I am using S3 bucket.
When i configure like below
ESP_LOGI(TAG, "Starting Advanced OTA example");
esp_err_t ota_finish_err = ESP_OK;
esp_http_client_config_t config = {
.url = CONFIG_EXAMPLE_FIRMWARE_UPGRADE_URL,
.cert_pem = NULL,
.timeout_ms = CONFIG_EXAMPLE_OTA_RECV_TIMEOUT,
.keep_alive_enable = true,
i am getting following error output on console
W (6711) esp_https_ota: Continuing with insecure option because CONFIG_ESP_HTTPS_OTA_ALLOW_HTTP is set.
I (6711) advanced_https_ota_example: OTA started
E (6941) esp-tls-mbedtls: No server verification option set in esp_tls_cfg_t structure. Check esp_tls API reference
E (6941) esp-tls-mbedtls: Failed to set client configurations, returned [0x8017] (ESP_ERR_MBEDTLS_SSL_SETUP_FAILED)
Need correct procedure to make it work the example code, using the S3 bucket. I need to use secured manner to perform the OTA.
Please enlight with any experience you have,
Thankyou,
Rahul B.
.cert_pem = NULL,
Thankyou,
Rahul B.
Re: Not able to perform OTA using ESP32 with AWS S3
Can you provide more info on how your S3 bucket is configured?
error "No server verification option set in esp_tls_cfg_t structure" suggests that you require a SSL/TLS certificate to make the connection.
you have set the .cert_pem = NULL, pointing to no certificate.
try using the default esp_crt_bundle and check the logs, you can enable mbedtls verbose logging for more clear debug logs
First of all, thank you so much for your reply.
I've configured the S3 bucket on AWS with public access. Inside this bucket, I've stored the "hello-world.bin" file for performing OTA updates.
and heres the output after verbose on showing no file
I (13645) advanced_https_ota_example: Starting Advanced OTA example
W (13645) esp_https_ota: Continuing with insecure option because CONFIG_OTA_ALLOW_HTTP is set.
D (13665) HTTP_CLIENT: Begin connect to: https://rahulawstestbucket1.s3.ap-south ... ws.com:443
D (13665) esp-tls: host:rahulawstestbucket1.s3.ap-south-1.amazo�aws.com: strlen 47
W (13855) wifi:<ba-add>idx:0 (ifx:0, 8a:e1:0b
4a:85), tid:0, ssn:4, winSize:64
V (13865) wifi:sta recv dup seq=64 tid=0, discard
D (13865) esp-tls: [sock=54] Resolved IPv4 address: 3.5.208.135
D (13865) esp-tls: [sock=k4] Connecting to server. HOST: rahulawstestbucket1.s3.ap-south-1.amazonaws.com, Port: 443
D (13965) esp-tls: handshake in progress...
D (15115) HTTP_CLIENT: Write header[3]: GET /hello-world.bin HTTP/1.1
User-Agent: ESP32 HTTP Client/1.0
Host: rahulawstestbucket1.s3.ap-south-1.amazonaws.com
Content-Length: 0
D (15275) HTTP_CLIENT: on_message_begin
D (15275) HTTP_CLIENT: HEADER=x-amz-request-id:9EJSVY16G778E79D
D (15275) HTTP_CLIENT: HEADER=x-amz-id-2:S7rP9YedZr4hlGYTbr+oSbzzhOYZnvopByE+aj28xKWYsMfOAEwECExxOPBcMc/l92JLnMBxJKXjOuXsgBO6mw==
D (15285) HTTP_CLIENT: HEADER=Content-Type:application/xml
D (15295) HTTP_CLIENT: HEADER=Transfer-Encoding:chunked
D (15295) HTTP_CLIENT: HEADER=Date:Fri, 26 Apr 2024 12:19:25 GMT
D (15305) HTTP_CLIENT: HEADER=Server:AmazonS3
D (15305) HTTP_CLIENT: http_on_headers_complete, status=403, offset=278, nread=278
D (15315) HTTP_CLIENT: content_length = -1
E (15315) esp_https_ota: File not found(403)
E (15325) esp_https_ota: Failed to establish HTTP connection
E (15335) advanced_https_ota_example: ESP HTTPS OTA Begin failed
if any other alternate way to perform OTA action please let me know
Thanks & Regards
Rahul B.
Content-Length: 0
Thanks & Regards
Rahul B.
now after debuging code I have got this error message,
I (6409) ota: Starting OTA
W (6410) esp_https_ota: Continuing with insecure option because CONFIG_OTA_ALLOW_HTTP is set.
E (6414) esp-tls: couldn't get hostname for :c6poednjo7.execute-api.ap-south-1.amazonaws.com: getaddrinfo() returns 202, addrinfo=0x0
E (6424) esp-tls: Failed to open new connection
E (6429) TRANSPORT_BASE: Failed to open a new connection
E (6436) HTTP_CLIENT: Connection failed, sock < 0
E (6441) esp_https_ota: Failed to open HTTP connection: ESP_ERR_HTTP_CONNECT
E (6448) esp_https_ota: Failed to establish HTTP connection
E (6455) ota: ESP HTTPS OTA Begin failed ESP_ERR_HTTP_CONNECT
is that any one knows about this issue please let me know
Thanks & Regards
Rahul B.
Thanks & Regards
Rahul B.
Did you ever try to modify your code like this?
.cert_pem = "/path/to/s3_certificate.pem", // Path to the PEM certificate file
// Ensure server verification is enabled
esp_tls_cfg_t tls_cfg = {
.cacert_buf = s3_server_certificate, // Provide the S3 server's certificate here
.cacert_bytes = sizeof(s3_server_certificate),
// Other fields such as client_cert_buf, client_cert_bytes, client_key_buf, client_key_bytes if required
// Set the TLS configuration
config.tls_cfg = &tls_cfg;
// Create and configure the HTTPS client with the provided configuration
I dont see issue here. I believe you have misconfiguration, sincethank you so much for your reply.
Thanks & Regards
Rahul B.
As for previous "issue", you just have to configure AWS-S3 bucket properly, so the file can be downloaded.
no it is not misconfiguration in aws s3 bucket because I have tested that api with thunder client and its showing status 200 OK means
api is working fine, so is that any other possible reason ?
@liaifat85Did you ever try to modify your code like this?Code: Select all
esp_http_client_config_t config = { .url = CONFIG_EXAMPLE_FIRMWARE_UPGRADE_URL, .cert_pem = "/path/to/s3_certificate.pem", // Path to the PEM certificate file .timeout_ms = CONFIG_EXAMPLE_OTA_RECV_TIMEOUT, .keep_alive_enable = true, }; // Ensure server verification is enabled esp_tls_cfg_t tls_cfg = { .cacert_buf = s3_server_certificate, // Provide the S3 server's certificate here .cacert_bytes = sizeof(s3_server_certificate), // Other fields such as client_cert_buf, client_cert_bytes, client_key_buf, client_key_bytes if required }; // Set the TLS configuration config.tls_cfg = &tls_cfg; // Create and configure the HTTPS client with the provided configuration esp_http_client_handle_t client = esp_http_client_init(&config);
first of all, Thank you for your reply, I appreciate your effort.
genrally iam using
.url = CONFIG_EXAMPLE_FIRMWARE_UPGRADE_URL, // here I have create GET api for fetch the code with bucket name and .bin file
.cert_pem = NULL, // becaused i dont used any server cirtificate here.
so i will try this code sniffet as you provide and let you know, Thanks alot
Thanks & regards,
Rahul B.
@chegewara ,I dont see issue here. I believe you have misconfiguration, sincethank you so much for your reply.
Thanks & Regards
Rahul B.As for previous "issue", you just have to configure AWS-S3 bucket properly, so the file can be downloaded.Code: Select all
I wanted to reach out to inform you of the progress, as well as a challenge I've encountered that I'm hoping you could assist me with.
So far, I have completed the following activities:
1) Created S3 buckets with public access and enabled bucket versioning to facilitate OTA updates and in that bucket store hello_world,bin file.
2) Developed REST APIs for GET operation, to access that file.
3) I am using stadard "advanced_https_ota" for my testing below are relevent code for this
.cert_pem = NULL,
.crt_bundle_attach = esp_crt_bundle_attach,
4) .cert_pem = NULL, because i dont want to used any cirtificate here
5) I have also try openssl rsa cirtifcate attached here but its showing error as
but when i am trying to do in menuconfig section select
component config ⇒ ESP- TLS ⇒
[*] Allow potentially insecure options
[*] Skip server certificate verification by default (WARNING: ONLY FOR TESTI
This will works fine.
But its insecure connection and i want secure connection with OTA .
At the moment, I don't know where to start or is this possible to do?! Do you have any ideas for this?
Please helppp !!! if any details required please let me know
Technical points:
- Tested with ESP-IDF v4.4.3
- ESP-WROOM-32E
- aws-S3
- aws-api-gateway
Thanks & Regards
Rahul B.
Users browsing this forum: Semrush [Bot] and 10 guests
