Generic Access(0x1800)
Posted: Sun Dec 17, 2017 11:50 am
by mkennyg555
hi,
I want to change the behavior of Generic Access (0x1800) in ESP32 / Arduino, how can I do it?
Specifically, I would like to add Peripheral Preferred Connection Parameters (00002a04).
thanks
Re: Generic Access(0x1800)
Posted: Mon Dec 18, 2017 11:11 pm
by kolban
I think you are asking ...
When we create a BLE Server using the ESP32 BLE software stack, the stack produces a service with UUID 0x1800 which has the name "Generic Access". See the following spec document:
https://www.bluetooth.com/specification ... access.xml
Associated with this service can be the optional characteristic with UUID 0x2a04 as described in this document spec:
https://www.bluetooth.com/specification ... meters.xml
However, when we start an ESP32 BLE Server, we find that the characteristic (0x2a04) is not present in the service (0x1800). Is there a way to add this characteristic or otherwise instruct the ESP32 to include it?
Posted: Thu Jan 24, 2019 12:36 pm
by elral6
I am running in the same problem that I need to set the optional characteristic with UUID 0x2a04.
I still reading the ebook ESP32, but unfortenutely I found no hint how to set this characteristic.
Is there any example or hint how to set optional characteristics for the service with UUID 0x1800?
Thanks and regards
Ralf
Posted: Fri Dec 13, 2019 1:29 pm
by ImaraSpeek
hi! This is exactly what I'd like to find out. Did you manage to find an answer to this question?
Best,
Imara
Posted: Thu Jan 16, 2020 12:47 pm
by jjwsei
Can anyone at Espressif provide a solution to the question:
When we start an ESP32 BLE Server, we find that the characteristic (0x2a04) is not present in the service (0x1800). Is there a way to add this characteristic or otherwise instruct the ESP32 to include it?
Thanks!
