Espressif IDE target not available
Grungel
Postby Grungel » Wed May 08, 2024 4:42 pm
I tried to create a new project for ESP32S3 using latest versions of both Espressif IDE and IDF.
However when I were to select the target ESP32S3 there is no such option!?
Where is this? Any fix?
Re: Espressif IDE target not available
Postby Sprite » Thu May 09, 2024 6:34 am
Are you sure you can't simply scroll down further than that, or enter 'esp32s3' yourself in the box for it to show up? Asking because the list seems to be ordered alphabetically, so the S3 would be lower than the options shown
stevenbennett
Postby stevenbennett » Sun May 19, 2024 4:57 pm
I had the same problem and many other obstacles to overcome, so for my benefit I wrote a step-by-step guide, which I have attached - I hope it's useful, it's not finished so I'll add updates when I can.
ESP-IDF on Eclipse info.pdf
Everything About ESP32, ESP-IDF on Eclipse, ESP-PROG and JTAG debugging
(278.58 KiB) Downloaded 261 times
