Newbie: I baught a ESP32 with a weird pin layout. How to identify GPxx pins?
NiklasG
Postby NiklasG » Thu May 16, 2024 4:49 pm
Hello everyone,
this is my first time working with an ESP32. But I have some Arduino experience.
I baught an ESP32-WROOM-32D and now I try to find documentation to the pin layout but cant find it (I didnt know there are SO MANY different versions).
My plan is to follow a tutorial to connect a round display (GC9A01) with the ESP32, because my Arduino is so slow and has not enough memory for bigger pictures.
https://www.youtube.com/watch?v=k2c2zCmC_X0 This is the tutorial.
https://www.aliexpress.com/item/1005006 ... pt=glo2deu this is the ESP i baught
My problem is, that I cant find the following GP Pins, because my ESP only has "Dxx" Pins and i cant find good documentation about it.
How can I identify the following pins?
GP23
GP18
GP22
GP16
GP4
The only pins I can identify are the GND and 3v3 ones :D
Thank you for helping!!
mikemoy
Re: Newbie: I baught a ESP32 with a weird pin layout. How to identify GPxx pins?
Postby mikemoy » Fri May 17, 2024 12:23 pm
This site here looks like the same pinout you have.
https://www.electronicshub.org/esp32-pinout/
Also, legit boards from espressif can be found here.
https://docs.espressif.com/projects/esp ... rted-guide
Basically treat the Dxx pins as GPxx.
NiklasG
Postby NiklasG » Fri May 17, 2024 2:10 pm
Thank you very much! Really helped!
Users browsing this forum: Perplexity-User and 1 guest
