BLE triggers an interrupt from GPIO
sokolsok
Postby sokolsok » Thu May 16, 2024 10:10 pm
Hey there,
A quick intro: In my project, I need to use interrupts on the falling edge for GPIO36 and GPIO39. I'm using ESP32 and FreeRTOS. Everything works flawlessly up to this point. First, I initialize the interrupts:
gpio_install_isr_service(0);
gpio_isr_handler_add(36, gpio_isr_handler, (void*) 36);
gpio_isr_handler_add(39, gpio_isr_handler, (void*) 39);
Next, I initialize the GPIO:
esp_err_t gpio_init(gpio_int_type_t type, gpio_mode_t mode, gpio_pulldown_t pull_down, gpio_pullup_t pull_up, int no)
    gpio_config_t io_conf = {};
    io_conf.intr_type = type;
    io_conf.mode = mode;
    io_conf.pin_bit_mask = (1ULL << no);
    io_conf.pull_down_en = pull_down;
    io_conf.pull_up_en = pull_up;
    return gpio_config(&io_conf);
static esp_err_t keyboard_gpio_init(void)
	static esp_err_t err;
	gpio_init(GPIO_INTR_NEGEDGE, GPIO_MODE_INPUT, GPIO_PULLDOWN_DISABLE, GPIO_PULLUP_DISABLE, 39);
	if(err != ESP_OK){
		return err;
	gpio_init(GPIO_INTR_NEGEDGE, GPIO_MODE_INPUT, GPIO_PULLDOWN_DISABLE, GPIO_PULLUP_DISABLE, 36);
	if(err != ESP_OK){
		return err;
    return ESP_OK;
The interrupt function itself looks like this:
void IRAM_ATTR gpio_isr_handler(void* arg)
    uint32_t gpio_num = (uint32_t) arg;
    xQueueSendFromISR(mcp23017_evt_queue, &gpio_num, NULL);
And the queue itself looks like this:
    while(1)
        if(xQueueReceive(mcp23017_evt_queue, &io_num, portMAX_DELAY))
        	printf("GPIO: %ld\n", io_num);
So far, so good. The problem starts when I add BLE support based on the example: "nimble->bleprph."
As soon as I add it, interrupts for pins 36 and 39 are automatically and cyclically triggered... I should mention that Bluetooth works fine then.
I ran a test and added just the initialization of these two GPIOs and the interrupts to a clean BLE example, and it's exactly the same problem..
Any ideas on what might be going wrong? I've been stuck on this for 2 days now and can't figure it out...
Thanks a lot!
meikuei
Re: BLE triggers an interrupt from GPIO
Postby meikuei » Tue Jan 21, 2025 4:41 pm
Hello, have you received any help ? I ran in same problem :roll:
Users browsing this forum: Google [Bot], PerplexityBot, Qwantbot and 4 guests
