I'm designing a pcb to use a esp32-c6-wroom ; I tested my code on a dev-board and it works fine.
I started to do a simple breakout board to bake the module on a pcb ang get each of it's pins. I connected 3,3v and EN to a power supply v+, gnd to gnd, usb_d+ to io13, usb_d- to io 12 : good news, it seems to connect and gets a com port.
Bad news (would not write here if everything was working), it seems to continually reboot : I did read the module's datasheet (https://espressif.com/documentation/esp ... eet_en.pdf) section 8 (peripheral schematics) and would like to have advice about what to add to make it work and keep the connection alive.
Bootstrapping pins? I don't what else could hepl.
Thanks in advance for any advice ; will give infos if needed (just ask).
advice about esp32-c6 pcb design
Re: advice about esp32-c6 pcb design
It does that when there's no valid code in flash. Pull GPIO9 low, reboot the chip, upload new code and reboot it again and it should work.
