Copy the image from partition to partition
Posted: Wed May 29, 2024 11:35 am
by aygh4266
Hello Everyone,
i am trying to copy a binary image located on a data fat partition to an app partition to set the boot from the app partition.
My Idea is to allocate a buffer and read and write the image in loop. Unfortunately is the copied image invalid and i keep getting these log messages:
E (3024) esp_image: image at 0x110000 has invalid magic byte (nothing flashed here?)
E (3034) example_main: Failed to set boot partition to OTA_0: ESP_ERR_OTA_VALIDATE_FAILED
Here is the code:
Code: Untitled.c Select all
 void copy_image_to_ota0() {
const esp_partition_t *storage_partition = esp_partition_find_first(ESP_PARTITION_TYPE_DATA, ESP_PARTITION_SUBTYPE_DATA_FAT, "storage");
if (!storage_partition) {
ESP_LOGE(TAG, "Storage partition not found");
return;
const esp_partition_t *ota_0_partition = esp_partition_find_first(ESP_PARTITION_TYPE_APP, ESP_PARTITION_SUBTYPE_APP_OTA_0, NULL);
if (!ota_0_partition) {
ESP_LOGE(TAG, "OTA_0 partition not found");
return;
if (storage_partition->size > ota_0_partition->size) {
ESP_LOGE(TAG, "Storage partition is larger than OTA_0 partition");
return;
ESP_LOGI(TAG, "Copying image from storage to OTA_0 partition");
const int BUFFER_SIZE = 4096;
void *buffer = malloc(BUFFER_SIZE);
if (!buffer) {
ESP_LOGE(TAG, "Failed to allocate memory for buffer");
return;
size_t offset = 0;
esp_err_t err;
while (offset < storage_partition->size) {
size_t bytes_to_copy = MIN(BUFFER_SIZE, storage_partition->size - offset);
err = esp_partition_read(storage_partition, offset, buffer, bytes_to_copy);
if (err != ESP_OK) {
ESP_LOGE(TAG, "Failed to read from storage partition at offset 0x%08x: %s", offset, esp_err_to_name(err));
free(buffer);
return;
err = esp_partition_write(ota_0_partition, offset, buffer, bytes_to_copy);
ESP_LOGE(TAG, "Failed to write to OTA_0 partition at offset 0x%08x: %s", offset, esp_err_to_name(err));
free(buffer);
return;
ESP_LOGD(TAG, "Copied %d bytes from offset 0x%08x", bytes_to_copy, offset);
offset += bytes_to_copy;
ESP_LOGI(TAG, "Image copied successfully to OTA_0 partition");
free(buffer);
Re: Copy the image from partition to partition
Posted: Wed May 29, 2024 3:19 pm
by liaifat85
You can try this edited version of your code:
#include "esp_partition.h"
#include "esp_log.h"
#include "esp_ota_ops.h"
#include <stdlib.h>
#define TAG "example_main"
        return;
        return;
        return;
    if (!buffer) {
        return;
    size_t offset = 0
Posted: Wed May 29, 2024 8:32 pm
by MicroController
Is there a FAT filesystem on this partition?
How do you get the image into this storage partition?
Posted: Thu Jun 20, 2024 8:58 am
by aygh4266
Yes, there is a FAT Parition in the partition table.csv
By Configuring the esp32s3 to act like Mass Storage device. So I can send the binary image direct from my PC or smartphone using USB OTG.
Posted: Thu Jun 20, 2024 11:17 am
by MicroController
You can't copy a FAT filesystem into an OTA partition and expect the FAT to be a valid firmware image.
Posted: Thu Jun 20, 2024 1:58 pm
by ok-home
why can't the OTA API
esp_ota_begin/esp_ota_write/esp_ota_end
be used with fread ?
