I decided to try out Rust for ESP development.
As first action I installed Rust on my Windows 11 computer using rustup.
After that I created a new project using cargo and a template from ESP-RS.
Running this template I got the option to use VsCode Devcontainer which was what I aimed for.
The create process went well and I started VsCode in the newly created folder.
VsCode recognized the Devcontainer configuration ant started up a container.
It took a while but finally I was up and running.
So, my problem:
- The rust analyzer shows a error:
cargo check failed to start: Cargo watcher failed, the command produced no valid metadata (exit code: ExitStatus(unix_wait_status(256))):
error: 'cargo-clippy' is not installed for the custom toolchain '/home/esp/.rustup/toolchains/nightly-x86_64-unknown-linux-gnu'.
note: this is a custom toolchain, which cannot use `rustup component add`
help: if you built this toolchain from source, and used `rustup toolchain link`, then you may be able to build the component with `x.py`There is another small but irritation error also.
The VsCode footer have a small "build" button. Press the button and you will be promted about you would like to build for "release" or "debug".
Whatever you select you will get this error:
Executing task: scripts/build.sh release
/bin/bash: line 1: scripts/build.sh: cannot execute: required file not found
* The terminal process "/bin/bash '-c', 'scripts/build.sh release'" failed to launch (exit code: 127).
* Terminal will be reused by tasks, press any key to close it.My Devcontainer is below.
"name": "test1",
// Select between image and build propieties to pull or build the image.
// "image": "docker.io/espressif/idf-rust:esp32c2_latest",
"build": {
"dockerfile": "Dockerfile",
"args": {
"CONTAINER_USER": "esp",
"CONTAINER_GROUP": "esp",
"ESP_BOARD": "esp32c2"
"settings": {
"editor.formatOnPaste": true,
"editor.formatOnSave": true,
"editor.formatOnSaveMode": "file",
"editor.formatOnType": true,
"lldb.executable": "/usr/bin/lldb",
"files.watcherExclude": {
"**/target/**": true
"rust-analyzer.checkOnSave.command": "clippy",
"rust-analyzer.checkOnSave.allTargets": false,
"[rust]": {
"editor.defaultFormatter": "rust-lang.rust-analyzer"
"extensions": [
"rust-lang.rust-analyzer",
"tamasfe.even-better-toml",
"serayuzgur.crates",
"mutantdino.resourcemonitor",
"yzhang.markdown-all-in-one",
"ms-vscode.cpptools",
"actboy168.tasks",
"Wokwi.wokwi-vscode"
"forwardPorts": [
3333,
8000
"workspaceMount": "source=${localWorkspaceFolder},target=/home/esp/test1,type=bind,consistency=cached",
"workspaceFolder": "/home/esp/test1"
