Install ESP-IDF: v5.2.2
VSCode: v1.90.0
ESP-IDF Extension: v1.7.1
I try to install ESP-IDF stable version(v5.2.2) in VSCode
But, I face error message when install it.
ESP-IDF was install in directory, but setup in vscode with esp-idf extension is not completed
Steps to reproduce.
1. Install VSCode and ESP-IDF Extension
2. write "ESP-IDF: Configure ESP-IDF extension" in command palette and click
3. click "EXPRESS"
4. Select ESP-IDF v5.2.2 and install
When complete install, face error message.
When creating an example in VSCode("ESP-IDF:Show Example Project" in the command palette), the ESP-IDF version v5.2.2 is not activated, and when checking the USE EXISTING SETUP item in "ESP-IDF: Configure ESP-IDF extension", v5.2.2 does not appear.
How can I complete setup?
Thanks.
ESP-IDF setup error in vscode with ESP-IDF extension
Re: ESP-IDF setup error in vscode with ESP-IDF extension
In Visual Studio Code select menu View then click Command Palette... and type ESP-IDF: Doctor Command to generate a report of your environment configuration and it will be copied in your clipboard to paste anywhere.
Check log file which can be obtained from:
Windows: %USERPROFILE%\.vscode\extensions\espressif.esp-idf-extension-VERSION\esp_idf_vsc_ext.log
Linux & MacOSX: $HOME/.vscode/extensions/espressif.esp-idf-extension-VERSION/esp_idf_vsc_ext.log
Could you share this information to find out the error ?
I found below in log file you mentioned:
Error: Command failed: \"d:\\esp\\espressif\\tools\\idf-python\\3.11.2\\python.exe\" \"d:\\esp\\v5.2.2\\esp-idf\\tools\\idf_tools.py\" install-python-env\nERROR: Python environment is set to d:\\esp\\espressif\\python_env\\idf5.2_py3.11_env which was generated for ESP-IDF v5.2.2 instead of the current 5.2. The issue can be solved by (1) removing the directory and re-running the install script, or (2) unsetting the IDF_PYTHON_ENV_PATH environment variable, or (3) re-runing the install script from a clean shell where an ESP-IDF environment is not active.
I tried the first method suggested in the log, and the installation appears to have completed normally in VSCode. It has been resolved, but I think the same problem appears to occur even if v5.2.2 is additionally installed in an environment where the v5.2 version is installed.
There is only one difference between IDF setup success and failure.
It just need to add `idf_version.txt` in <IDF_TOOLS_PATH>\python_env\idf5.2_py3.11_env before download or search ESP-IDF setup.
Content of `idf_version.txt` file is `5.2`.
We should have a fix in this vsix installer and it will be part of the next v1.8.0 release.
You can try by uninstall your current esp-idf vscode extension and install the vsix from the link with Install from VSIX command in vscode.
Users browsing this forum: Amazon [Bot] and 0 guests
