Hey guys
I am using ESP32 with esp-idf on a ESP32 Thing from Sparkfun.
I have a rgb-LED on pins 12-14. Now i have the Problem that during deep sleep the red led (pin 14) is always slightly shining.
Pin 14 is configured as GPIO --> PIN_FUNC_SELECT(GPIO_PIN_MUX_REG[14], PIN_FUNC_GPIO);
Why is this the case? And is there any possibility to turn off this port during deep sleep?
My deep sleep config is: esp_sleep_pd_config(ESP_PD_DOMAIN_MAX, ESP_PD_OPTION_OFF);
Thanks for your help.
ESP32 - Pin14 LED
Re: ESP32 - Pin14 LED
See RTC HOLD PAD feature, I think this can help you.
Thanks a lot, urbanze. But that does not seem to be the case...
I added the following code to my main:
rtc_gpio_force_hold_dis_all();
This should disable rtc hold on any rtc-pins. But nothing changed. Any other ideas?
According to the schematic, Pin 14 is also HSPI_CLK. What about this?
You need to put GPIO LOW and after HOLD this GPIO, like this:
Before, try this two codes and see difference!
Note: You can use any function to set output HIGH, in this case I will use Arduino functions.
Note 2: GPIO 14 has an LED to show hold feature working.
How can you see, after ESP32 go to deep sleep, LED go LOW (in theory). Now, try with hold feature.
Now, after deep sleep, LED still HIGH.
You need to put GPIO14 LOW and HOLD, try!
In my test's after deep sleep, GPIO14 go to tri-state or ?? (~1.5V). When use GPIO14>LOW and HOLD, pin still in 0V.
pinMode(14, OUTPUT);
digitalWrite(14, 1);
delay(500);
esp_deep_sleep(300000000);
rtc_gpio_hold_en(GPIO_NUM_14);
delay(500);
Wow, thank you for your efforts!
You were right! It works if i set gpio_14 to low and enable hold before going to deep sleep. After waking up, i have to disable the hold so that the LED works again.
That's fine for me, thanks a lot!
Yes! you need to disable hold to use pin after wake up. Good luck with your projectkumart wrote:Wow, thank you for your efforts!
Users browsing this forum: No registered users and 31 guests
