I2S - can wroom be slave and receive pcm data?
Posted: Thu Jun 20, 2024 12:20 pm
by colinz
I'm new to I2S and there is not much information about how to set it as slave and receive pcm data. What i've tried is two esp32 S3-wroom as i2s master and slave based on the official I2S example > FullDuplex, if i change the communication_format to I2S_COMM_FORMAT_I2S, the slave's serial will print a serials of "0", its not what i sent but it's another problem. But if i change both master and slave to I2S_COMM_FORMAT_STAND_PCM_SHORT, the slave will not print at all. Is there other thing i need to do to receive PCM data? I only wired bck, ws, and data in or out three lines, the mclk is floating. The slave code is like:
Code: Untitled.cpp Select all
#include "driver/i2s.h"
i2s_config_t i2s_config = {
.mode = (i2s_mode_t)(I2S_MODE_SLAVE | I2S_MODE_TX | I2S_MODE_RX),
.sample_rate = 8000,
.bits_per_sample = I2S_BITS_PER_SAMPLE_16BIT,
.channel_format = I2S_CHANNEL_FMT_RIGHT_LEFT,
.communication_format = I2S_COMM_FORMAT_STAND_PCM_SHORT,
.intr_alloc_flags = ESP_INTR_FLAG_LEVEL1,
.dma_buf_count = 8,
.dma_buf_len = 256,
.use_apll = true,
i2s_pin_config_t pin_config = {
.bck_io_num = 4,
.ws_io_num = 5,
.data_out_num = 7,
.data_in_num = 6
uint16_t rxbuf[256];
size_t readsize = 0;
void setup(){
i2s_set_pin(I2S_NUM_0, &pin_config);
Serial.begin(115200);
void loop(){
readsize=0;
i2s_read(I2S_NUM_0, &rxbuf[0], 3, &readsize, 100);
if(readsize > 0){
for(int i = 0; i < readsize; i++){
Serial.print(rxbuf[i]);
Serial.print(" ");
Serial.println();
