I just cant win with these timers.
Posted: Sat Jun 22, 2024 11:12 am
G'day guys.
Basically, I have no business trying to write code, but yet, i give it a crack anyway.
Having trouble with timers however i try to do it though.
Keep in mind though, that i have no external hardware attached at this point, so if that's the reason for the errors I'm asking about, please allow me to apologize in advance.
Anyhow, on with the show. (also please forgive my impending code pasting errors. First time here)
My current code;
And the output from the serial monitor;
Now, could anybody spare the time to tell me what i'm doing wrong?
Thanks in advance.
My current code;
#define TIMER_BASE_CLK 80000000 // Add this line at the top of your code
#include <dummy.h>
#include <ESP32TimerInterrupt.h> // Include the ESP32TimerInterrupt library
#include "BluetoothSerial.h"
// Define sensor and ignition pins
#define SENSOR_PIN1 18
#define SENSOR_PIN2 19
#define SENSOR_PIN3 22
#define SENSOR_PIN4 23
#define IGNITION_PIN1 25
#define IGNITION_PIN2 26
// Define timing constants
#define TIMING_AT_LOW_RPM 8.0
#define TIMING_AT_HIGH_RPM 25.0
#define LOW_RPM 1000.0
#define HIGH_RPM 5000.0
#define COIL_CHARGE_TIME 3000 // Coil charge time in microseconds
// Declare volatile variables for interrupt tracking
volatile unsigned long lastInterruptTime1 = 0;
volatile unsigned long lastInterruptTime2 = 0;
volatile unsigned long lastInterruptTime3 = 0;
volatile unsigned long lastInterruptTime4 = 0;
volatile float rpm2 = 0;
volatile float rpm4 = 0;
// Declare other necessary variables
unsigned long ignitionStartTime = 0;
bool ignitionStarted = false;
volatile bool interruptOccurred = false; // Flag for interrupt occurrence
BluetoothSerial SerialBT;
// Declare timer objects
ESP32Timer ITimer0(0);
ESP32Timer ITimer1(1);
// Function prototypes
float getTiming(float rpm);
void controlIgnition1(float rpm);
void controlIgnition2(float rpm);
void handleBluetoothMessage(String message);
bool IRAM_ATTR onTimer0(void*); // Modify the function signature
bool IRAM_ATTR onTimer1(void*); // Modify the function signature
void setup() {
Serial.begin(9600); // Initialize serial communication
// Initialize sensor and ignition pins
pinMode(SENSOR_PIN1, INPUT);
pinMode(SENSOR_PIN2, INPUT);
pinMode(SENSOR_PIN3, INPUT);
pinMode(SENSOR_PIN4, INPUT);
pinMode(IGNITION_PIN1, OUTPUT);
pinMode(IGNITION_PIN2, OUTPUT);
// Attach interrupts to sensor pins
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN1), calculateRPM1, FALLING);
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN2), calculateRPM2, FALLING);
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN3), calculateRPM3, FALLING);
attachInterrupt(digitalPinToInterrupt(SENSOR_PIN4), calculateRPM4, FALLING);
// Initialize timers
ITimer0.attachInterruptInterval(10000, onTimer0); // Timer 0, interval 10000us
ITimer1.attachInterruptInterval(10000, onTimer1); // Timer 1, interval 10000us
SerialBT.begin("ESP32test"); // Initialize Bluetooth Serial
void loop() {
while (!interruptOccurred) {
// Waiting for interruptOccurred to become true
if (SerialBT.available()) {
String message = SerialBT.readString();
handleBluetoothMessage(message);
// Once interruptOccurred is true, the following code will execute
float avgRpm = (rpm2 + rpm4) / 2.0; // Average RPM from sensors 2 and 4
float timing = getTiming(avgRpm);
controlIgnition1(timing);
controlIgnition2(timing);
SerialBT.println("RPM: " + String(avgRpm) + ", Timing: " + String(timing));
// Reset interruptOccurred to false for the next cycle
void calculateRPM1() {
lastInterruptTime1 = micros();
interruptOccurred = true; // Add this line
void calculateRPM2() {
unsigned long currentTime = micros();
unsigned long timeDifference2 = currentTime - lastInterruptTime2;
if (timeDifference2 < 1000 || timeDifference2 == 0) { // Debounce, ignore if interrupt fires within 1ms or if timeDifference is zero
return;
SerialBT.println("timeDifference2: " + String(timeDifference2)); // Add this line
rpm2 = 60000000.0 / timeDifference2; // 1 edges per revolution
lastInterruptTime2 = currentTime;
void calculateRPM3() {
lastInterruptTime3 = micros();
void calculateRPM4() {
unsigned long timeDifference4 = currentTime - lastInterruptTime4;
if (timeDifference4 < 1000 || timeDifference4 == 0) { // Debounce, ignore if interrupt fires within 1ms or if timeDifference is zero
return;
SerialBT.println("timeDifference4: " + String(timeDifference4)); // Add this line
rpm4 = 30000000.0 / timeDifference4; // 2 edges per revolution
lastInterruptTime4 = currentTime;
float getTiming(float rpm) {
float slope;
if (HIGH_RPM == LOW_RPM) {
// Handle error: HIGH_RPM and LOW_RPM should not be equal
Serial.println("Error: HIGH_RPM and LOW_RPM should not be equal");
slope = 1.0; // Set a default slope value
} else {
slope = (TIMING_AT_HIGH_RPM - TIMING_AT_LOW_RPM) / (HIGH_RPM - LOW_RPM);
float intercept = TIMING_AT_LOW_RPM - slope * LOW_RPM;
return slope * rpm + intercept;
void controlIgnition1(float timing) {
float delay = timing - COIL_CHARGE_TIME; // calculate delay for coil 1
if (delay > 0) {
ITimer0.attachInterruptInterval(delay, onTimer0);
void controlIgnition2(float timing) {
float delay = timing - COIL_CHARGE_TIME; // calculate delay for coil 2
if (delay > 0) {
ITimer1.attachInterruptInterval(delay, onTimer1);
bool IRAM_ATTR onTimer0(void*) { // Modify the function signature
digitalWrite(IGNITION_PIN1, HIGH);
delayMicroseconds(COIL_CHARGE_TIME);
digitalWrite(IGNITION_PIN1, LOW);
return true;
bool IRAM_ATTR onTimer1(void*) { // Modify the function signature
digitalWrite(IGNITION_PIN2, HIGH);
digitalWrite(IGNITION_PIN2, LOW);
return true;
void handleBluetoothMessage(String message) {
if (message.startsWith("RPM:")) {
rpm2 = rpm4 = message.substring(4).toFloat();
// Add more conditions here to handle other settings
Y�4]q�5�p�2�y���%`�E (15) timer_group: timer_init(301): only support Level Interrupt
E (15) timer_group: timer_set_counter_value(92): HW TIMER NEVER INIT ERROR
E (31) timer_group: timer_set_alarm_value(165): HW TIMER NEVER INIT ERROR
E (109) timer_group: timer_enable_intr(230): HW TIMER NEVER INIT ERROR
E (184) timer_group: timer_isr_callback_add(266): HW TIMER NEVER INIT ERROR
E (264) timer_group: timer_start(103): HW TIMER NEVER INIT ERROR
E (333) timer_group: timer_init(301): only support Level Interrupt
E (403) timer_group: timer_set_counter_value(92): HW TIMER NEVER INIT ERROR
E (484) timer_group: timer_set_alarm_value(165): HW TIMER NEVER INIT ERROR
E (563) timer_group: timer_enable_intr(230): HW TIMER NEVER INIT ERROR
E (638) timer_group: timer_isr_callback_add(266): HW TIMER NEVER INIT ERROR
E (718) timer_group: timer_start(103): HW TIMER NEVER INIT ERRORThanks in advance.
