ESP32 S3 Segmented SPI Transfer -SEG_TRANS_DONE interrupt never triggers!
faptastic
Postby faptastic » Tue Jul 02, 2024 1:21 am
I have created a 'simple' example of using ESP32S3's Segmented Transfer mode for SPI in order to create a continuous loop.
However, I can NEVER get it to trigger a SPI_DMA_SEG_TRANS_DONE_INT interrupt never seems to trigger, no matter what I do.
https://github.com/mrcodetastic/esp32s3 ... x_seg_loop
I have this function that ends the transfer by setting the linked list to end, but even that won't cause an interrupt to be generated!
// Doesn't quite clean up cleanly.
esp_err_t spi_transfer_loop_stop(void) {
  const spi_bus_attr_t* bus_attr = spi_bus_get_attr(SPI2_HOST);
  // Disconnect the looping DMA transfer to cause the transfer to finish
  ESP_LOGD(TAG, "Calling spi_transfer_loop_stop()");
  dma_data_lldesc[dma_lldesc_required-1].eof = 1;
  dma_data_lldesc[dma_lldesc_required-1].qe.stqe_next = NULL;
  return ESP_OK;
Two functions are run in sequential order to start things off, the first one to use the esp-idf driver framework to set the registers of the GPSPI2 peripheral, then a second function to interact with it again to set segmented transfer and kick off a loop of output.
esp_err_t spi_transfer_loop_start()
  // Setup interrupt
  static intr_handle_t intr;
  esp_intr_alloc        (ETS_SPI2_DMA_INTR_SOURCE,  ESP_INTR_FLAG_SHARED, dma_isr3, NULL, &intr);
  esp_intr_alloc        (ETS_SPI2_INTR_SOURCE,      ESP_INTR_FLAG_SHARED, dma_isr3, NULL, &intr);
  esp_intr_enable       (intr);
  dma_isr3(0); // increase count to 1
  esp_err_t err;
  // Dispatch transaction; link_trans will finish it off
  ESP_LOGD(TAG, "Initial Transfer");
  static spi_transaction_t trans;
  trans.flags     = SPI_TRANS_MODE_OCT;
  // What do we do here? TO DO, send null packet just to kick off transfer?
  // https://www.esp32.com/viewtopic.php?p=123221#p123211
  trans.tx_buffer = spi_tx_payload_testchunk2;
  trans.length = (sizeof(spi_tx_payload_testchunk2)) * 8;
  trans.rx_buffer = NULL;
  trans.rxlength = 0;
  CHECK_CALLE(spi_device_polling_start(spi_device, &trans, portMAX_DELAY), "Could not start SPI transfer");
  //esp_register_shutdown_handler(vga_deinit);
  ESP_LOGD(TAG, "spi_transfer_loop_start() complete");
  return ESP_OK;
esp_err_t spi_transfer_loop_start_2()
  // Need to do first start first to set registers.
  ESP_LOGD(TAG, "Part 2");
  // TODO; Figure out a way to get interrupts working, and when the GCLK segement has completed and about to restert - then allow a DCLK / Greyscale transfer
  //       AT THE SAME TIME
 // esp_intr_alloc_intrstatus(ETS_SPI2_INTR_SOURCE, ESP_INTR_FLAG_SHARED, (uint32_t)&GPSPI2.dma_int_st.val, SPI_DMA_SEG_TRANS_DONE_INT_ENA_M, dma_isr2,  NULL, &intr);
  GPSPI2.slave.dma_seg_magic_value = 0xA;
  // hal->dmadesc_tx = &dma_data_lldesc[0]; // START OFF A DESCRIPTOR 0
  spi_dma_ll_tx_reset(&GDMA, bus_attr->tx_dma_chan);
  spi_ll_dma_tx_fifo_reset(&GPSPI2);
  spi_ll_outfifo_empty_clr(&GPSPI2);
  spi_ll_dma_tx_enable(&GPSPI2, 1);
  spi_dma_ll_tx_start(&GDMA, bus_attr->tx_dma_chan, &dma_data_lldesc[0]);
  GPSPI2.slave.usr_conf = 1;  // Enable user conf for segmented transfers
  GPSPI2.user.usr_conf_nxt = 1;
  GPSPI2.misc.cs0_dis = 1;    // turn off client select pin
  // 13. Set SPI_DMA_SEG_TRANS_DONE_INT_ENA to enable the SPI_DMA_SEG_TRANS_DONE_INT interrupt.
  //     Configure other interrupts if needed according to Section 30.10.
  //esp_intr_free(spi_device->host->intr);
  spi_ll_clear_intr(&GPSPI2, SPI_LL_INTR_TRANS_DONE); // need this for the transacion to start
  spi_ll_clear_intr(&GPSPI2, SPI_LL_INTR_SEG_DONE); // need this for the transacion to start
  GPSPI2.dma_int_ena.dma_seg_trans_done = 1; // Doesn't work, so can't use it. :-(
  GPSPI2.dma_int_ena.trans_done = 1; // Doesn't work, so can't use it. :-(
  GPSPI2.cmd.conf_bitlen = 0;
  // Configure interrupt
  //       AT THE SAME TIME
  //spi_ll_clear_int_stat (spi_device->host->hal.hw);
  GPSPI2.cmd.update = 1;
  while (GPSPI2.cmd.update);    //waiting config applied
  // start trans
  GPSPI2.cmd.usr = 1;
  ESP_LOGD(TAG, "spi_transfer_loop_start_2() complete");
  return ESP_OK;
Any ideas?
faptastic
Re: ESP32 S3 Segmented SPI Transfer -SEG_TRANS_DONE interrupt never triggers!
Postby faptastic » Wed Jul 03, 2024 9:30 pm
Figured out the problem.
Ending the DMA transfer does not trigger an interrupt by the SPI device. It just sits there in silence. You need to zero out SPI_USR_CONF_NXT to trigger an interrupt.
Solution here: https://github.com/mrcodetastic/esp32s3 ... x_seg_loop
Users browsing this forum: Amazon [Bot], Qwantbot, Semrush [Bot] and 1 guest
