InstrFetchProhibited at cpu_start: Pro cpu start user code
Posted: Fri Jul 05, 2024 10:05 am
by leschge
we have a bigger project where a lot of code was added in a separate branch. This branch works fine until its merged into the main branch. The code does not have any obvious flaws, which could explain the error below.
I am a bit confused what needs to happen, that a crash triggers directly where cpu_start: Pro cpu start user code should be printed. Maybe somebody can help me there. Thanks.
entry 0x403c9994
W (27) boot.esp32s3: eFuse virtual mode is enabled. If Secure boot or Flash encryption is enabled then it does not provide any security. FOR TESTING ONLY!
I (44) boot: ESP-IDF v5.0.1-1-g6c39d4de9e-dirty 2nd stage bootloader
I (44) boot: compile time 17:20:47
I (44) boot: chip revision: v0.1
I (47) qio_mode: Enabling default flash chip QIO
I (53) boot.esp32s3: Boot SPI Speed : 80MHz
I (58) boot.esp32s3: SPI Mode       : QIO
I (62) boot.esp32s3: SPI Flash Size : 16MB
I (67) boot: Enabling RNG early entropy source...
I (73) boot: Partition Table:
I (76) boot: ## Label            Usage          Type ST Offset   Length
I (83) boot:  0 otadata          OTA data         01 00 0000d000 00002000
I (91) boot:  1 reserved         WiFi data        01 02 0000f000 00001000
I (98) boot:  2 ota_0            OTA app          00 10 00010000 00300000
I (106) boot:  3 ota_1            OTA app          00 11 00310000 00300000
I (113) boot:  4 prod             Unknown data     01 ff 00710000 00001000
I (121) boot:  5 reserved1        Unknown data     01 ff 00711000 00002000
I (128) boot:  6 safeNVrb0        Unknown data     01 ff 00713000 00010000
I (136) boot:  7 safeNVrb1        Unknown data     01 ff 00723000 00010000
I (143) boot:  8 safeNVrb2        Unknown data     01 ff 00733000 00010000
I (151) boot:  9 config           WiFi data        01 02 00743000 00046000
I (159) boot: 10 shared           WiFi data        01 02 00789000 00003000
I (166) boot: 11 appl             WiFi data        01 02 0078c000 00004000
I (174) boot: 12 nvs_key          NVS keys         01 04 00790000 00001000
W (181) efuse: Loading virtual efuse blocks from flash
EFUSE_BLKx:
0) 0x08001000 0x00000010 0x0000d1f5 0x00000800 0x80000000 0x00000000
1) 0xfac1ae04 0x0000f412 0x00000000 0x02040000 0x14183ad0 0x7006c818
2) 0xceb57472 0xa32474b0 0xfdb5be9d 0x496793a0 0x916b75f1 0xefdaaebb 0xa6c0a8a9 0x4078f8b0
3) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
4) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
5) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
6) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
7) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
8) 0xd4fb0c9b 0x98f13ef0 0x3cf17473 0x5ff4032b 0x2b67c16b 0xcf05809d 0xb113f091 0x76807ec9
9) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
10) 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
I (273) boot: 13 efuse_em         efuse            01 05 00791000 00002000
I (281) boot: 14 coredump         Unknown data     01 03 00793000 00040000
I (289) boot: 15 log              Unknown data     01 ff 007d3000 00040000
I (296) boot: 16 fifo             Unknown data     01 ff 00813000 00100000
I (304) boot: 17 diagtool2        Unknown data     01 82 00913000 006ed000
I (311) boot: End of partition table
I (316) SSBL: Selected boot partition: 0
[SSBL] Custom bootloader message defined in the KConfig file.
I (325) SSBL: calculated CRC: 0x02B928F2
I (330) SSBL: reprFlCrc:      0x02B928F2
I (335) SSBL: pReprogFlag addr: 0x50000010
I (339) SSBL: magicNum: 0xAA5555AA
I (344) SSBL: reprogFlag: 0xBABACECA
I (348) SSBL: resetReasonFlag: 0xFFFFFFFF
I (352) SSBL: The CRC of Reprogramming flag structure valid!
I (359) SSBL: Factory flag is set!
I (363) SSBL: Reset Reprogramming flag
I (367) SSBL: calculated CRC: 0x02B928F2
I (372) SSBL: reprFlCrc:      0x02B928F2
I (377) SSBL: pReprogFlag addr: 0x50000010
I (381) SSBL: magicNum: 0xAA5555AA
I (385) SSBL: reprogFlag: 0xBABACECA
I (390) SSBL: resetReasonFlag: 0xFFFFFFFF
I (394) SSBL: Loading Image -1 (-1: factory | 0/1: main app)
I (401) esp_image: segment 0: paddr=00010020 vaddr=3c1a0020 size=88cb4h (560308) map
I (495) esp_image: segment 1: paddr=00098cdc vaddr=3fc9f500 size=0733ch ( 29500) load
I (500) esp_image: segment 2: paddr=000a0020 vaddr=42000020 size=19fd08h (1703176) map
I (760) esp_image: segment 3: paddr=0023fd30 vaddr=3fca683c size=00b78h (  2936) load
I (761) esp_image: segment 4: paddr=002408b0 vaddr=40374000 size=1b4b8h (111800) load
I (787) esp_image: segment 5: paddr=0025bd70 vaddr=600fe000 size=0003ch (    60) load
I (799) boot: Loaded app from partition at offset 0x10000
I (800) boot: Disabling RNG early entropy source...
I (811) esp_psram: Found 2MB PSRAM device
I (812) esp_psram: Speed: 80MHz
I (812) cpu_start: Pro cpu up.
I (812) cpu_start: Starting app cpu, entry point is 0x40375a0c
0x40375a0c: call_start_cpu1 at C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_system/port/cpu_start.c:142
I (786) cpu_start: App cpu up.
I (1049) esp_psram: SPI SRAM memory test OK
Guru Meditation Error: Core  1 panic'ed (InstrFetchProhibited). Exception was unhandled.
Core  1 register dump:
PC      : 0x00000000  PS      : 0x00060034  A0      : 0x80375fd8  A1      : 0x3fcecc70
A2      : 0x3fcecce0  A3      : 0x00000000  A4      : 0x00000000  A5      : 0x00000001
A6      : 0x00000001  A7      : 0x00000000  A8      : 0x820047e4  A9      : 0x3fcecc50
A10     : 0x00000000  A11     : 0x00000000  A12     : 0x42005060  A13     : 0x3fcecfa0
0x42005060: esp_panic_handler_reconfigure_wdts at C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_system/panic.c:182
A14     : 0x00000001  A15     : 0x3fca1458  SAR     : 0x00000007  EXCCAUSE: 0x00000014
EXCVADDR: 0x00000000  LBEG    : 0x400570e8  LEND    : 0x400570f3  LCOUNT  : 0xffffffff
Backtrace: 0xfffffffd:0x3fcecc70 0x40375fd5:0x3fceccc0 0x403779e4:0x3fcecce0 0x3ffffffd:0x3fcecda0 |<-CORRUPTED
0x40375fd5: xt_unhandled_exception at C:/Espressif/frameworks/esp-idf-v5.0.1/components/esp_system/port/panic_handler.c:223
0x403779e4: _xt_user_exc at C:/Espressif/frameworks/esp-idf-v5.0.1/components/freertos/FreeRTOS-Kernel/portable/xtensa/xtensa_vectors.S:709
Re: InstrFetchProhibited at cpu_start: Pro cpu start user code
Posted: Fri Jul 05, 2024 12:16 pm
by Sprite
Hard to say and the backtrace isn't very telling. Anything you do that enables any interrupts?
