uart_read_bytes
Posted: Fri Dec 29, 2017 11:42 pm
by shelladdicted
int uart_read_bytes(uart_port_t uart_num, uint8_t *buf, uint32_t length, TickType_t ticks_to_wait)
Docs is not clear enough, this function return only after that ticks_to_wait (aka 20 / portTICK_RATE_MS)[/code] are passed?
or can return as soon length bytes are available (before that ticks_to_wait expire)?
Re: uart_read_bytes
Posted: Sat Dec 30, 2017 7:22 pm
by tele_player
I haven’t tried it, but functions like this usually return immediately if the requested data is available. The alternative doesn’t make sense.
Re: uart_read_bytes
Posted: Sun Dec 31, 2017 1:26 am
by kolban
In your original post you asked if we waited or returned immediately when the "length" bytes were available. I think you shouldn't discount a third option which I believe may also exist ... that it returns immediately if LESS than "length" bytes are available but at least 1 byte. For example, if the UART has 5 bytes waiting to be read and you pass in a buffer of 100 bytes into which the data will be stored, my belief is that it will return immediately having populated 5 bytes and telling you that it read those 5 bytes into the buffer. This is not the same as "waiting for 100 bytes to be read".
Re: uart_read_bytes
Posted: Sun Dec 31, 2017 7:26 pm
by shelladdicted
this^ is exactly what I need,
maybe i haven't been clear enough in my question,
with length I mean the bytes that i expect to read (always < than *buf length) not the length of *buf
my code is
uint8_t cmd[4];
//obviously, here i populate *cmd
//then Send
uart_write_bytes(_uartPort, (const char*) cmd, 4); // Send Command (composed by 4 bytes), and i expect 4bytes to read (ACK)
// some other code here
// check for ACK
int rxBytes = uart_read_bytes(_uartPort, data, 4, 20 / portTICK_RATE_MS); // read 4 bytes OR timeout
if (rxBytes > 0) {
// DO SOMETHING
else{
	// Err :-(
with this code uart_read_bytes() will return as soon 4 bytes are ready or will ALWAYS wait for 20ms?
Re: uart_read_bytes
Posted: Tue Jun 05, 2018 4:57 am
by kolban
You will likely be able to return immediately (without blocking) is you specify a timeout of 0. You will be returned what ever set of UART bytes are immediately available but no more than the length you requested. You may get 0 bytes if no UART data is immediately available.
Re: uart_read_bytes
Posted: Thu Dec 01, 2022 2:15 pm
by Giuseppe1412
I don't understand the difference between :
uart_set_rx_timeout and the TickType_t ticks_to_wait in uart_read_bytes.
I think that if in :
uart_read_bytes(uart_num, buf, length, ticks_to_wait)
I set:
length=5
and rx timeout=1, (the time to receive a byte to the baud setted)
If I don't receive 5 byte before the timeout expired, in the buf I have the bytes that I received;
if I received 3 bytes: 0xA, 0xB, 0xC,
I have: len=3 buf[0]=0xA, buf[1]=0xb,....
but what is ticks_to_wait for?
I tried to print a messange exchange between two peripherals:
1) I write from periph 1 to periph 2 with: uart_write_bytes, 5 bytes
2) In periph 1 read the responce of periph 2 with uart_read_bytes. (the responce is 9 byte)
3) send an ack from periph 1 to periph 2 (3 byte)
If I set rx timeout=1 and ticks_to_wait=100, I can send the ack after 100 ms, if I set ticks_to_wait=50, I can send the ack after 50 ms,
If I set the ticks_to_wait=10 ms I receive corrupted byte in 2) and also the ack that I send in 3) appears to be corrupted.
Thanks.
Best regards.
