I am building a custom board around the esp32-c6-mini-1 module and I was wondering if I could directly flash the in-module spi flash through the built-in usb jtag using the espressif provided openocd or if I needed a real jtag connection ( by burning the efuses ) with a flash loader or the only way to program the chip is by using the internal bootloader.
Sorry if this is a duplicate question but i googled for a bit and did not find a definitive answer.
Thank you!
Usb serial / jtag question
Re: Usb serial / jtag question
You can. Be aware that on a boot with empty flash, ESPs tend to bootloop, so you may need to force it to download mode to get a proper connection. Also be aware that it may be easier to use the serial mode (using esptool.py) to upload flash; you can also do that over the same hardware.
Users browsing this forum: PerplexityBot and 2 guests
