ESP32C6 keeps crashing with Zigbee Example
HesselJ
Postby HesselJ » Wed Jul 31, 2024 4:51 pm
I've been trying to upload the Zigbee_Light_Bulb example to a Seeed Studio XIAO ESP32C6 but it keeps crashing.
I've selected the board as seen in the attachments. When I open the serial monitor I see these messages:
18:50:29.372 -> Guru Meditation Error: Core  0 panic'ed (Load access fault). Exception was unhandled.
18:50:29.372 ->
18:50:29.372 -> Core  0 register dump:
18:50:29.372 -> MEPC    : 0x40031c8a  RA      : 0x4080c0fc  SP      : 0x40819520  GP      : 0x4080d840
18:50:29.372 -> TP      : 0x4080a11c  T0      : 0x37363534  T1      : 0x7271706f  T2      : 0x33323130
18:50:29.372 -> S0/FP   : 0x00000001  S1      : 0x00000011  A0      : 0x00000000  A1      : 0xffffffff
18:50:29.372 -> A2      : 0x00000001  A3      : 0x7f7f7f7f  A4      : 0x00000000  A5      : 0x00000004
18:50:29.372 -> A6      : 0x0000000c  A7      : 0x76757473  S2      : 0x000000b6  S3      : 0x40819550
18:50:29.372 -> S4      : 0x40819568  S5      : 0x42037d84  S6      : 0x00000000  S7      : 0x00000000
18:50:29.372 -> S8      : 0x00000000  S9      : 0x00000000  S10     : 0x00000000  S11     : 0x00000000
18:50:29.372 -> T3      : 0x6e6d6c6b  T4      : 0x6a696867  T5      : 0x66656463  T6      : 0x62613938
18:50:29.372 -> MSTATUS : 0x00001881  MTVEC   : 0x40800001  MCAUSE  : 0x00000005  MTVAL   : 0x00000000
18:50:29.372 -> MHARTID : 0x00000000
18:50:29.372 ->
18:50:29.372 -> Stack memory:
18:50:29.372 -> 40819520: 0x00000004 0x00000000 0x40814e5c 0x00000000 0x00000000 0x00000000 0x40814e5c 0x40800030
18:50:29.372 -> 40819540: 0x00000000 0x4080e66c 0x4080e668 0x4080e9bc 0x00000000 0x4080e67c 0x4081953c 0x4080e680
18:50:29.372 -> 40819560: 0x00000000 0x4080e1c4 0x00000000 0x00000000 0x00000000 0x65737361 0x66207472 0x656c6961
18:50:29.372 -> 40819580: 0x08203a64 0x00000020 0x40814cb0 0x40802a2a 0x40814220 0x00000140 0x40814cb0 0x40814e5c
18:50:29.372 -> 408195a0: 0x42049188 0x00000000 0x40814cb0 0x4205c44a 0x00000000 0x00000000 0x4087cd70 0x40807d20
18:50:29.372 -> 408195c0: 0x00000004 0x40814000 0x00000003 0xffffffff 0x4081656c 0x40880000 0x40814220 0x40022574
18:50:29.372 -> 408195e0: 0x40814220 0x00000054 0x4087cd70 0x40807234 0x00000000 0x00000000 0x4087cd70 0x4080776a
18:50:29.372 -> 40819600: 0x00000000 0x00000000 0x00000000 0x000000ff 0x40880000 0x4081656c 0x40814220 0x400225ca
18:50:29.372 -> 40819620: 0x40814000 0x40816574 0x40814220 0x4080aef0 0x40814000 0x00000000 0x40816574 0x7e295a9f
18:50:29.372 -> 40819640: 0x00000000 0x00000004 0xffffffff 0x00000000 0x00000000 0x00000000 0x00000000 0x4080f480
18:50:29.372 -> 40819660: 0x4206f000 0x40811480 0x4080f000 0x42037d84 0x40809534 0x00000000 0x4080f000 0x4200fe82
18:50:29.372 -> 40819680: 0x4080a11c 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x408196c0 0x4200400a
18:50:29.372 -> 408196a0: 0x00000000 0x00000000 0x00000000 0x42000076 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408196c0: 0x00000002 0x00000000 0x00000006 0x00000bb8 0x00000000 0x00000000 0x00000000 0x40809540
18:50:29.372 -> 408196e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819700: 0x00000000 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xa5a5a5a5 0xbaad5678 0x0000334c
18:50:29.372 -> 40819720: 0xabba1234 0x00003340 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819740: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819760: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819780: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408197a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408197c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408197e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819800: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819820: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819840: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819860: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819880: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408198a0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408198c0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 408198e0: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.372 -> 40819900: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
18:50:29.512 ->
18:50:29.512 ->
18:50:29.512 ->
18:50:29.512 -> ELF file SHA256: dcdf3c7c210dafbf
18:50:29.512 ->
18:50:29.512 -> Rebooting...
18:50:29.512 -> ESP-ROM:esp32c6-20220919
18:50:29.512 -> Build:Sep 19 2022
18:50:29.512 -> rst:0xc (SW_CPU),boot:0x1e (SPI_FAST_FLASH_BOOT)
18:50:29.512 -> Saved PC:0x4001975a
18:50:29.512 -> SPIWP:0xee
18:50:29.512 -> mode:DIO, clock div:2
18:50:29.512 -> load:0x4086c410,len:0xc64
18:50:29.512 -> load:0x4086e610,len:0x2758
18:50:29.512 -> load:0x40875728,len:0x594
18:50:29.512 -> entry 0x4086c410
Re: ESP32C6 keeps crashing with Zigbee Example
Postby Sprite » Thu Aug 01, 2024 12:17 am
Can you decode that stack trace?
HesselJ
Postby HesselJ » Thu Aug 01, 2024 7:59 pm
How do I do this? I dont have a lot of experience with using ESP devices.
Postby Sprite » Fri Aug 02, 2024 2:48 am
HesselJ
Postby HesselJ » Sat Aug 03, 2024 11:31 pm
Sadly I cant open the terminal of the one you send and other ones. But I just used the example so it should work right.
HesselJ
Postby HesselJ » Sun Aug 04, 2024 1:53 pm
Oh and btw I also tried to program it in Visual Studio Code and it worked there. But I really want to use the Arduino IDE and language.
ondra@spsstavbrno.cz
Postby ondra@spsstavbrno.cz » Sat Nov 02, 2024 11:46 am
I have the same problem, I tried it on the Seeed Studio XIAO ESP32C6 board and the ESP32-C6-DEVKITM-1-N4 board. Tested on Arduino IDE 2.3.3 with ESP32 3.0.7 .
