ESP-Now which sending information to 2 led on and off with 2 buttons.
Posted: Tue Aug 06, 2024 9:23 am
I'm making a system with one green and one red led. it must communicate to thee ESP's The script I rewrite is not working " good " it is with ESP-Now I hope someone good find what is wrong.The code I rewrite:
// Script rewrite with 2 led's and two buttons which is NOT correct !
// Include Libraries
#include <WiFi.h>
#include <esp_now.h>
// Define LED and push button state booleans
bool buttonDown_2 = false;
bool ledOn_2 = false;
bool buttonDown_1 = false;
bool ledOn_1 = false;
// Define LED and pushbutton pins
#define STATUS_LED_1 15
#define STATUS_BUTTON_1 5
#define STATUS_LED_2 14
#define STATUS_BUTTON_2 4
void formatMacAddress(const uint8_t *macAddr, char *buffer, int maxLength)
// Formats MAC Address
snprintf(buffer, maxLength, "%0xFF:%0xFF:%0xFF:%0xFF:%0xFF:%0xFF", macAddr[0], macAddr[1], macAddr[2], macAddr[3], macAddr[4], macAddr[5]);
//void receiveCallback(const uint8_t *macAddr, const uint8_t *data, int dataLen)
void receiveCallback(const esp_now_recv_info_t* esp_now_info, const uint8_t *data, int dataLen)
// Called when data is received
// Only allow a maximum of 250 characters in the message + a null terminating byte
char buffer[ESP_NOW_MAX_DATA_LEN + 1];
int msgLen = min(ESP_NOW_MAX_DATA_LEN, dataLen);
strncpy(buffer, (const char *)data, msgLen);
// Make sure we are null terminated
buffer[msgLen] = 0;
// Format the MAC address
//char macStr[18];
//formatMacAddress(macAddr, macStr, 18);
// Send Debug log message to the serial port
//Serial.printf("Received message from: %s - %s\n", macStr, buffer);
Serial.printf("Received message %s\n", buffer);
// Check switch status
if (strcmp("on", buffer) == 0)
ledOn_1 = true;
else
ledOn_1 = false;
digitalWrite(STATUS_LED_1, ledOn_1);
ledOn_2 = true;
else
ledOn_2 = false;
digitalWrite(STATUS_LED_2, ledOn_2);
void sentCallback(const uint8_t *macAddr, esp_now_send_status_t status)
// Called when data is sent
char macStr[18];
Serial.print("Last Packet Sent to: ");
Serial.println(macStr);
Serial.print("Last Packet Send Status: ");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void broadcast(const String &message)
// Emulates a broadcast
// Broadcast a message to every device in range
uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
esp_now_peer_info_t peerInfo = {};
memcpy(&peerInfo.peer_addr, broadcastAddress, 6);
if (!esp_now_is_peer_exist(broadcastAddress))
esp_now_add_peer(&peerInfo);
// Send message
esp_err_t result = esp_now_send(broadcastAddress, (const uint8_t *)message.c_str(), message.length());
// Print results to serial monitor
if (result == ESP_OK)
Serial.println("Broadcast message success");
else if (result == ESP_ERR_ESPNOW_NOT_INIT)
Serial.println("ESP-NOW not Init.");
else if (result == ESP_ERR_ESPNOW_ARG)
Serial.println("Invalid Argument");
else if (result == ESP_ERR_ESPNOW_INTERNAL)
Serial.println("Internal Error");
else if (result == ESP_ERR_ESPNOW_NO_MEM)
Serial.println("ESP_ERR_ESPNOW_NO_MEM");
else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
Serial.println("Peer not found.");
else
Serial.println("Unknown error");
void setup()
// Set up Serial Monitor
Serial.begin(115200);
delay(1000);
// Set ESP32 in STA mode to begin with
WiFi.mode(WIFI_STA);
Serial.println("ESP-NOW Broadcast Demo");
// Print MAC address
Serial.print("MAC Address: ");
Serial.println(WiFi.macAddress());
// Disconnect from WiFi
WiFi.disconnect();
// Initialize ESP-NOW
if (esp_now_init() == ESP_OK)
Serial.println("ESP-NOW Init Success");
esp_now_register_recv_cb(receiveCallback);
esp_now_register_send_cb(sentCallback);
else
Serial.println("ESP-NOW Init Failed");
delay(3000);
ESP.restart();
// Pushbutton uses built-in pullup resistor
pinMode(STATUS_BUTTON_1, INPUT_PULLUP);
pinMode(STATUS_BUTTON_2, INPUT_PULLUP);
// LED Output
pinMode(STATUS_LED_1, OUTPUT);
pinMode(STATUS_LED_2, OUTPUT);
void loop()
if (digitalRead(STATUS_BUTTON_1))
// Detect the transition from low to high
if (!buttonDown_1)
buttonDown_1 = true;
// Toggle the LED state
ledOn_1 = !ledOn_1;
if (digitalRead(STATUS_BUTTON_2))
if (!buttonDown_2)
buttonDown_2 = true;
ledOn_2 = !ledOn_2;
// Send a message to all devices
if (ledOn_1)
broadcast("on");
else
broadcast("off");
if (ledOn_2)
broadcast("on");
else
broadcast("off");
// Delay to avoid bouncing
delay(500);
else
// Reset the button state
