Hello everyone,
I'm trying to work with the INA219 on ESP-IDF.
I'm having a really hard time trying to port any Arduino libraries to ESP-IDF, and the library: https://github.com/UncleRus/esp-idf-lib ... nts/ina219, which should already be fully ported, just isn't working for me. It shows a bunch of incompatibilities, and seems dependent on various third-party libraries that shouldn’t be necessary.
On Arduino and PIC, everything is so simple, but I'm really struggling with ESP-IDF and can't get my INA219 to work.
Does anyone have a minimal I2C library that I could use as a base to implement the INA219? Or better yet, does anyone have a fully functional INA219 library?
Thanks in advance!
Help with INA219 Library on ESP-IDF
MicroController
Re: Help with INA219 Library on ESP-IDF
What does that mean?It shows a bunch of incompatibilities,
What third-party libraries are you referring to? And what's the issue with one component using another component instead of duplicating its code?and seems dependent on various third-party libraries that shouldn’t be necessary.
Note that you need to check out the whole 'library' (https://github.com/UncleRus/esp-idf-lib/tree/master), not just the code of one component, as the components in that library depend on each other.
Have you tried the example?
How about https://docs.espressif.com/projects/esp ... s/i2c.html ? Or https://github.com/Nore5515/i2c_ina219 ?Does anyone have a minimal I2C library that I could use as a base to implement the INA219?
Users browsing this forum: ChatGPT-User, Qwantbot and 1 guest
