Is the ESP32-WROOM-32 capable of frequency analysis?
Jim_Stuart
Postby Jim_Stuart » Wed Aug 14, 2024 12:23 am
Hello, I'm working on a project right now that basically modulates sound waves using a photodiode: CJMCU-101, which is a breakout board for the OPT101 photosensor. The idea is that I shine a laser (color right now is red) onto a mirror that is attached to a speaker. The mirror will vibrate and the reflected light ray will vibrate at a specific frequency that I play through a mirror and onto the photosensor. I want to capture the frequency of the sound wave that the speaker plays.
My question is, can an ESP32-WROOM-32 handle the frequency analysis required to analyze the photosensor readings and process the information to get the frequency of the speaker?
Or, should I use another microcontroller?
OPT101 Datasheet: https://www.ti.com/lit/ds/symlink/opt101.pdf
Re: Is the ESP32-WROOM-32 capable of frequency analysis?
Postby Sprite » Wed Aug 14, 2024 5:20 am
The ESP32 in there is more than capable of handling basic audio-frequency DSP stuff. Depending on your algorithm and what else you want to do with the signal, you may also want to consider an ESP32-S3-based module as it can do hardware-accelerated FFT and filtering stuff.
Users browsing this forum: Perplexity-User, Qwantbot and 3 guests
