new to esp32
donreypirata
new to esp32
Postby donreypirata » Tue Aug 20, 2024 10:07 pm
Hi, I'm new to esp32, I got the esp32 s-3 devout c-1 board and the esp32-c3 devout m1, but I can't identify which are the i2c pins in the s-3, in the c3 are clearly identified in the documentation, all help will be appreciated.
Re: new to esp32
Postby Sprite » Wed Aug 21, 2024 2:44 am
ESP32 chips don't have dedicated pins for that; you can select any of them to be used for I2C. (Note that some SDKs, like Arduino, do use default pins if you don't specify any, but that's an SDK thing, not something that is enforced in hardware.)
donreypirata
Re: new to esp32
Postby donreypirata » Wed Aug 21, 2024 2:10 pm
thank you, I didn't know that, any instruction on how to do that?
Re: new to esp32
Postby Sprite » Thu Aug 22, 2024 12:49 am
Depends on the SDK. Which one are you using?
charansai
Re: new to esp32
Postby charansai » Thu Aug 22, 2024 11:45 am
hii i am getting this error while compiling can anyone can help me...
else if(subMenuPage==2){
      lcd.setCursor(0,0);lcd.print("CHARGING CURRENT");
      if(setMenuPage==1){lcd.setCursor(0,1);lcd.print(" >");}
      else{lcd.setCursor(0,1);lcd.print("= ");}
      lcd.setCursor(2,1);lcd.print(currentCharging,2);lcd.print("A");
      lcd.print("                ");
      //SET MENU - FLOATTYPE
      if(setMenuPage==0){floatTemp = currentCharging;}
      else{
        if(digitalRead(buttonBack)==1){while(digitalRead(buttonBack)==1){}currentCharging = floatTemp;setMenuPage=0;}
        if(digitalRead(buttonSelect)==1){while(digitalRead(buttonSelect)==1){}saveSettings();setMenuPage=0;}
        currentMenuSetMillis = millis();
        if(digitalRead(buttonRight)==1){                                                  //Right button press (increments setting values)
          while(digitalRead(buttonRight)==1){
            if(millis()-currentMenuSetMillis>longPressTime){                              //Long Press
              currentCharging += 1.00;                                                    //Increment by 1
              currentCharging = constrain(currentCharging,0.0,cOutSystemMax);             //Limit settings values to a range
              lcd.setCursor(2,1);lcd.print(currentCharging,2);delay(longPressInterval);   //Display settings data
            else{        //Short Press
              currentCharging += 0.01;                                                    //Increment by 0.01
              lcd.setCursor(2,1);lcd.print(currentCharging,2);delay(shortPressInterval);  //Display settings data
            lcd.print("A   ");                                                            //Display unit
        else if(digitalRead(buttonLeft)==1){                                              //Left button press (decrements setting values)
          while(digitalRead(buttonLeft)==1){
              currentCharging -= 1.00;                                                    //Increment by 1
            else{        //Short Press
              currentCharging -= 0.01;                                                    //Increment by 0.01
Error:
Code: Untitled.c Select all
...8_LCD_Menu:377:1: error: insn does not satisfy its constraints:
377 | }
(insn 11 2651 1185 127 (set (reg:SF 19 f0 [orig:127 _95 ] [127])
(mem/u/c:SF (symbol_ref/u:SI ("*.LC357") [flags 0x2]) [0 S4 A32])) "C:\Users\chara\Downloads\CODE_MPPT_ESP32_V1.2.1-20240819T055256Z-001\CODE_MPPT_ESP32_V1.2.1\8_LCD_Menu.ino":205:33 49 {movsf_internal}
(expr_list:REG_EQUAL (const_double:SF 0.0 [0x0.0p+0])
(nil)))
during RTL pass: postreload
C:\Users\chara\Downloads\CODE_MPPT_ESP32_V1.2.1-20240819T055256Z-001\CODE_MPPT_ESP32_V1.2.1\8_LCD_Menu.ino:377:1: internal compiler error: in extract_constrain_insn, at recog.cc:2692
Please submit a full bug report, with preprocessed source (by using -freport-bug).
See <https://gcc.gnu.org/bugs/> for instructions.
exit status 1
insn does not satisfy its constraints: ...'''
Error image
WhatsApp Image 2024-08-21 at 2.14.12 PM.jpeg (63.14 KiB) Viewed 2373 times
donreypirata
Re: new to esp32
Postby donreypirata » Thu Aug 22, 2024 4:08 pm
im using the Arduino ide to program the boards
Re: new to esp32
Postby Sprite » Thu Aug 22, 2024 11:53 pm
Please post that in a separate topic.
You can set the GPIOs when initializing the TwoWire object. For e.g.GPIO 12 and 13, you would do something like
TwoWire I2Cbus = TwoWire(0);
I2Cbus.begin(12, 13, 100000);
See here for some more examples.
donreypirata
Re: new to esp32
Postby donreypirata » Fri Aug 23, 2024 10:31 pm
great, thank you very much, I will try it this weekend, really appreciate your help
