Issue connecting ESP32-S3 to LCD Display Screen.
Posted: Fri Aug 30, 2024 9:49 pm
#include <hd44780.h>
#include <Wire.h>
// Define the GPIO pins connected to the LCD
const int rs = 10;
const int en = 9;
const int d4 = 7;
const int d5 = 6;
const int d6 = 5;
const int d7 = 4;
// Initialize the library with the numbers of the interface pins
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// include the library code:
void setup() {
// set up the LCD's number of columns and rows:
lcd.begin(16, 2); // 16 columns, 2 rows
// Print "Hello World!" to the LCD
lcd.setCursor(0, 0); // Set cursor to the first column of the first row
lcd.print("Hello World!");
void loop() {
}I used this configuration to connect to my esp32-s3, although I changed some of the pins since the example here uses a wroom:
https://www.circuitschools.com/interfac ... thout-i2c/
How should I connect the LCD such that the esp32-s3 can properly display text?
