[esp-eye] Station mode wifi disconnected
Posted: Thu Sep 05, 2024 1:53 am
IDF version.
v4.4.0
Operating System
Windows
build project
VS Code IDE
v4.4.0
Operating System
Windows
build project
VS Code IDE
Code: Untitled.c Select all
uint8_t eth_mac[6];
char mkSsid[32];
char SetPwd[32];
memset(SetPwd, 0, sizeof(SetPwd));
ESP_ERROR_CHECK(esp_netif_init());
ESP_ERROR_CHECK(esp_event_loop_create_default());
esp_netif_create_default_wifi_ap();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
setDns();
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_APSTA)); //WIFI_MODE_AP
ESP_ERROR_CHECK(esp_event_handler_register(WIFI_EVENT, ESP_EVENT_ANY_ID, &dwd_event_handler, NULL));
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, ESP_EVENT_ANY_ID, &dwd_event_handler, NULL));
esp_wifi_get_mac(ESP_IF_WIFI_AP, eth_mac);
if(pSysinfo->DeviceMeasureType == DWD_TYPE_THREE_100A)
sprintf(mkSsid, DWD_SSID_PREPIX_3P100A"%02x%02x%02x", eth_mac[3], eth_mac[4], eth_mac[5]);
}else if(pSysinfo->DeviceMeasureType == DWD_TYPE_THREE_400A)
sprintf(mkSsid, DWD_SSID_PREPIX_3P400A"%02x%02x%02x", eth_mac[3], eth_mac[4], eth_mac[5]);
}else if(pSysinfo->DeviceMeasureType == DWD_TYPE_THREE_800A)
sprintf(mkSsid, DWD_SSID_PREPIX_3P800A"%02x%02x%02x", eth_mac[3], eth_mac[4], eth_mac[5]);
}else
sprintf(mkSsid, DWD_SSID_PREPIX_1P"%02x%02x%02x", eth_mac[3], eth_mac[4], eth_mac[5]);
sprintf(pSysinfo->mac_st, "%02x%02x%02x%02x%02x%02x", eth_mac[0], eth_mac[1], eth_mac[2], eth_mac[3], eth_mac[4], eth_mac[5]);
wifi_config_t wifi_config = {
.ap = {
.max_connection = DWD_MAX_STA_CONN,
//.authmode = WIFI_AUTH_WPA_WPA2_PSK,
//.ssid_hidden = false,
.beacon_interval = 100
if (dwd_wifi_events == NULL) {
dwd_wifi_events = xEventGroupCreate();
memset(&(wifi_config.ap.ssid[0]), 0, sizeof(wifi_config.ap.ssid));
memset(&(wifi_config.ap.password[0]), 0, sizeof(wifi_config.ap.password));
wifi_config.ap.ssid_len = sprintf((char *)&wifi_config.ap.ssid, "%s", mkSsid);
if (strlen(SetPwd) == 0)
wifi_config.ap.authmode = WIFI_AUTH_OPEN;
ESP_LOGI(TAG, "wifi_init_softap finished. SSID[%d]:%s", wifi_config.ap.ssid_len, mkSsid);
}else
wifi_config.ap.authmode = WIFI_AUTH_WPA_WPA2_PSK;
sprintf((char *)&wifi_config.ap.password, "%s", SetPwd);
ESP_LOGI(TAG, "wifi_init_softap finished. SSID:%s password:%s", mkSsid, SetPwd);
ESP_ERROR_CHECK(esp_wifi_set_config(ESP_IF_WIFI_AP, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_ERROR_CHECK(esp_wifi_set_protocol(ESP_IF_WIFI_AP, WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N));
start_webserver();
Open a webpage in softap mode, enter nvs information there, save it, reboot it, and connect wifi in station mode, but the connection is successful and then disconnected right away.
I'd really appreciate it if you could tell me how to solve it
