Hi All,
Have a strange one but I have flashed a board with custom firmware using the Rainmake zigbee gateway example as a base. I can succesfully claim the device and get it enrolled into my dashboard with everything working well. However throughout the day the board will disconnect and then reconnect a couple of seconds later. In the Rainmaker app under notifications I see hundreds of offline then online messages. The device reconnects within random times of 2 - 80 seconds. I doubt it is the wifi strength issue as I have it transmitting data back to insights and RSSI normally sits at about -40db and when the errors happen there is no difference in RSSI at that time. Also in the same location I had it running as a Zigbee coordinator sending MQTT packets back to a Mosquitto broker without any issues.
Is there some kind of session setting with the Rainmaker MQTT broker that I need to tweek to stop it reporting online offline messages randomly?
I am getting the attached error messages through Insights, not sure why it thinks I haven't uploaded a firmware package but I have uploaded the latest ZIP that is flashed on the device.
Device keeps on disconnecting and re-connecting to Rainmaker via MQTT
- Screenshot 2024-09-23 165313.png (220.17 KiB) Viewed 20178 times
Re: Device keeps on disconnecting and re-connecting to Rainmaker via MQTT
Hi @djorr5,
From logs, as you have observed, it seems the device is getting connected and then disconnected frequently. The Insights logs however, are not much useful.
- Does the raw example(without any custom changes) work as expected?
- Can you please share more context: IDF version used, the chipset used?
- Can you check if you have by mistake flashed the same certificates on multiple devices? If so, only one device can be active at the same time.
Now the Insights logs not getting resolved case:
If you've the IDF >= 5.2, there is a bug in the Insights sha reporting for latest IDFs, which manifests backend into not getting match for the firmware and hence logs not getting resolved.
You may find the discussion and a fix being discussed here:
https://github.com/espressif/esp-insights/issues/45
https://github.com/espressif/esp-insights/pull/47
If you have the IDF version >= release/v5.2, do try the fixes discussed above and share the resolved logs.
Hey, thanks for the reply and info on Insights issue. I have rectified as per the post and now get correct error messages. To give you more details about the setup:
Using ESP32S3 on a custom board connected via UART to a H2 for Zigbee and this has worked well when I configured it as a Zigbee coordinator using only the ESP Zigbee SDK talking to HA via MQTT.
I am using IDF 5.3 as I was getting build errors with 5.4 and managed to resolve it by using 5.3 instead.
There shouldn't be the same certificates on more than 1 board, but I have flashed the same code to 2 different boards whilst developing. One I used assisted claiming and the other I used the CLI to claim for admin rights and another account to claim via the Rainmaker app. Is there a way to check in the dashboard which certificates are being used? I currently only have 1 board online anyway.
After updating the settings I now get the logs in Insight. Looking at the logs it shows:
The other thing I have noticed is that it stops updating Insights after a certain number of days.
Update: I reflashed the board on the 29th and so far haven't had any offline messages. I am wondering if it fails once I bring another board online. Wouldn't a different certificate get provisioned to the board based on claiming? I am not using my own certificates.
- Screenshot 2024-09-30 091510.png (291.55 KiB) Viewed 19845 times
So after working without issues for a week it suddenly starts disconnecting and reconnecting again. I had over 60 disconnect and reconnects early on the 12th October. Nothing shows up in Insights though, it is only notifications to the App. No changes to code, no changes to network infrastructure and the amount of data being transferred is very minimal. Any idea what could be going on?
I have connected a laptop to it in situ and as I have re-powered the device it has stopped with the disconnect re-connect messages for now. Will have a look at the logs as soon as it starts up again.
I had simillar issue - mqtt client running at esp32-s3 was disconnecting from its broker running at AWS (IoT Core) after a few seconds. It was regardless of mqtt_cfg.network.refresh_connection_after_ms setting to 0 value at the esp32 mqtt client library.
I had 2 devices connected, and mqtt client id/name was hardcoded info client's code, so effectively both devices were using the same name.
Then after a few days I have realized the issue does not happen when only one device is connected (the other one was powered off at the time).
Conclussion: each device shall have its own mqtt client name. Otherwise "mirracles" can happen...
AWS validates the client id in: AWS IoT-> Security->Policies->myPolicyName , do just need to add/edit iot::Connect Allow Policy pointing the unique client name.
I don't think this is my issue as I only have 1 device connected to Rainmaker. Even to this day it still happens. I have extended timeouts but still it randomly goes offline, then comes back online straight away.
