ESP Flash Speed
Alberk
ESP Flash Speed
Postby Alberk » Thu Sep 26, 2024 4:14 am
I have the ESP32 WROVER E (Rev 3) development board and a bit confused with the the esptool commands
The sdkconfig has the following option compiled.
CONFIG_ESPTOOLPY_FLASHMODE_QIO=y
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
CONFIG_SPIRAM_SPEED_80M=y
What is the purpose of the esptool flash_mode ?
esptool.py write_flash --flash_mode
MicroController
Re: ESP Flash Speed
Postby MicroController » Thu Sep 26, 2024 6:32 am
I believe the SDK config is baked into the firmware so that the bootloader can set up the flash upon boot of the firmware, while the --flash_mode is used by the esptool to (temporarily) configure the flash for esptool's purposes.
Alberk
Re: ESP Flash Speed
Postby Alberk » Thu Sep 26, 2024 7:32 am
Thanks.
Does that mean it does not matter if I use the esptool parameter to flash the firmware ? assuming the firmware is built with the speed configurations.
Users browsing this forum: Amazon [Bot], Qwantbot and 2 guests
